ET streets or drag radial?
These will only be used for the track. Car is a 01 z06.
Will 17inch z06 front rims work on the rear with drag radials?
Also what would be best mt et streets or mt drag radials?
And what sizes.
Thanks for all the help guys.
YES.
And what sizes.
Rwhp?
Mods?
Possible future mods?
Clutch?
These tires should be run with skinnies and that requires a drack pack.
As for drag radials they have come a long way in the past 5 years.
IMO, Hoosier drag radials are one of the best for cars with 400-500rwhp.
I'd go with a 16" or 17"(cheapest solution). You don't need very wide tires either, they can slow you down. If you run a hoosier in 17" on a front c5 z06 rim that should work well but I'd air them up quite a bit with 385 rwhp and a stock clutch. Something like 25lbs and a small burnout.
Talk to some of the resident racers in this performance section.
Then as you increase rwhp and go with shorter gears, you can air them down and take more advantage of the tire.
At 500rwhp with 4.10 gears and a manual I think you should evolve your setup into a drag pack with either bias ply rears and skinnies or drag radials and skinnies.
A Hoosier 275 40 17 drag radial is a nice option.
Proven advice above.
Thanks for the offer but I have a set of 17" z06 rims.
I'm trying to find tires for them.
