Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Is it possible...
Old May 3, 2011 | 02:15 PM
PRE-Z06's Avatar
PRE-Z06
Default Is it possible...
Just in case my little 346 doesn't hold up for a 10.4 run in the fall. I've been contemplating my next build and wanted to get a few expert opinions. I'll give a few details to see if y'all think it's possible to go 9's with ~550rwhp and sub 3100lb raceweight...
  • 6.0L with ~12:1 CR
  • SNL VX cam (max effort grind)
  • CNC small bore LS7 heads
  • 1.875" headers and cut-outs
  • MN12 with 4.10 gears
  • EWP and 7200rpm limiter
  • 1.4 60' on a Level 2 Monster
Old May 3, 2011 | 02:35 PM
Fartpipe's Avatar
Fartpipe
Nope
Old May 3, 2011 | 02:45 PM
paint it black vette's Avatar
close. maybe a road trip to east this dec for some good da will get it done
Old May 3, 2011 | 03:28 PM
PRE-Z06's Avatar
PRE-Z06
Yeah that is one variable I can't control and know it's going to take some -DA to gitter done
Old May 3, 2011 | 05:00 PM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by Fartpipe
Nope
Thanks, for the encouragement sunshine! Gotta admit I never thought your car would go as fast as it has with you behind the wheel
Old May 3, 2011 | 05:19 PM
nickolbag's Avatar
nickolbag
Easy.
Old May 3, 2011 | 05:30 PM
Rob Petyo's Avatar
Rob Petyo
what are you doing to the little 346 that you think it won't hold up?
Old May 3, 2011 | 06:56 PM
PRE-Z06's Avatar
PRE-Z06
It's got 112k "hard" miles on it and is getting tired...has a slight tick, I think from bumping the limiter to 7k and was datalogging 7200 between shifts
Old May 3, 2011 | 09:30 PM
stonabones69's Avatar
stonabones69
Tirecraft says Fartpipe is gay too! Just Sayin...
Old May 4, 2011 | 08:56 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I think it's possible if everything comes together for that perfect pass. Why are you setting the limiter at 7200? run it as high as the cam still makes power...
Old May 4, 2011 | 09:25 AM
robz's Avatar
robz
Yes.
Old May 4, 2011 | 10:54 AM
Devilish34's Avatar
Devilish34
Who makes the small bore LS7 heads?
Old May 4, 2011 | 11:00 AM
PRE-Z06's Avatar
PRE-Z06
Originally Posted by robz
Yes.
Thank you Rob, if you say it can be done then I have faith
Old May 4, 2011 | 11:03 AM
PRE-Z06's Avatar
PRE-Z06
I picked 7200 as that'll be the estimated rpm I'll be going thru the traps (~138)...we've bumped the limiter in Matt's GTO to 7500 just to see how well the clutch works at that speed, but the intake is going to be the limiting factor more than the cam at that point.
Old May 4, 2011 | 11:46 AM
Fartpipe's Avatar
Fartpipe
I would limit the times to 7200rpm due to the stock rod bolts IMO. You're asking for BOOM at that point.
I think the car will need to be lighter, driver will have to be beaten into submission and then rebuilt from the ground up left constant left leg presses and right arm pull ups only. Then a strict diet of cabbage and egg milk. Then and only then may you become ready to begin your journey into...... the highlight zone.
Old May 4, 2011 | 12:13 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
says the quiter that couldnt get his C5 to run fast, so he bailed and got a C6Z... Why do we still let him in here???
Old May 4, 2011 | 01:43 PM
Fartpipe's Avatar
Fartpipe
Wait did you run 10.81@130mph with a H/C/I yet? Oh yeah thats right
Those damn rears are expensive when they start popping like popcorn at the movie theater with a new Fast and the furious playing!
To Is it possible...
Old May 11, 2011 | 11:58 AM
TwoValveKid's Avatar
TwoValveKid
+1...RPM makes them...and texas speed supposedly has them "for sale" (according to LS1tech). Definitely curious to see what kind of power they make on a non LS7 427 bore....compared to ported/potential aftermarket LS3's.
Old May 11, 2011 | 12:14 PM
TriplBlk's Avatar
TriplBlk
Since its a new build why would he keep stock rod bolts? Especially when katech's are only $200
Old May 11, 2011 | 01:38 PM
option 2 forge the bottom end and stroke it, main studs, heads studs add a little juice and you'll be in the nines easy if you can launch without breaking the drive train
