Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Dyno after mods...low numbers?
Old May 10, 2011 | 02:52 PM
Sidieux's Avatar
Sidieux
Default Dyno after mods...low numbers?
I had my car dynoed after I did a few mods and thought it seemed a little low. I had my car dynoed last summer and made the same I am at now, why is this with these setups?
03 C5 Z06
Stock LS6 heads
double springs
Harland Sharp 1.7 rockers
233/239 TSP Cam 112LSA
ls2 timing chain
ls6 ported oil pump
Vararam air intake
25% Underdrive pully
Bassani 421 headers with x pipe and GHl exhaust
New plugs and wires
180 stat
With that setup I made 399rwhp. Is this low?
Last summer I made 398rwhp and I had a 216/224 113lsa cam and stock harmonic balancer.
Would a 160 stat make that much of a difference?? What is the culprit?
Old May 10, 2011 | 03:47 PM
pit-man's Avatar
pit-man
03 C5 Z06
Stock LS6 heads
double springs
ls2 timing chain
ls6 ported oil pump
Vararam air intake
New plugs and wires
180 stat
Last summer I made 398rwhp and I had a 216/224 113lsa cam.
First was it the same Dyno ? Mustang or Dyno Jet ? Were the dyno results output in the same format (SAE corrected, Std..ect) ? Did you make more than one pull (wondering if the motor was hot enough) ? The LS motors like to be at least 185 degrees from what I hear. There could be alot of different factors. Do you have the same rear tires and rims ? Heavy after market rims will kill ya on the dyno. Do you have bigger tires now ?
Old May 10, 2011 | 03:54 PM
slowtealz28's Avatar
slowtealz28
Dont worry bout dyno numbers, take it to the track to see the real world gains.
Old May 10, 2011 | 03:57 PM
Sidieux's Avatar
Sidieux
I forgot to add. Last summer I had stock harmonic balancer, now I have a 25% under drive one.
Last summer I had CCW 505a 19x11 with nitton invo tires. Now I have 19x11 c6z chrome ones as I got sick of cleaning the 505's for a DD. I now have hankook v12 on them.
Last summer was on a mustang dyno, this time it was on a dynojet. So this is normal, I didnt really gain any HP with the bigger cam?
Old May 10, 2011 | 04:14 PM
pit-man's Avatar
pit-man
Your dyno numbers don't make sense as the Mustang Dyno reads lower than a Dyno Jet. If the Mustang was accurate, your new Dyno Jet numbers should have been a lot higher. Also, those chrome wheels are probably a lot heavier than the CCW wheels. That would have dropped the numbers some.
I lost 17 rwhp with different wheels/tires on my Silverado. I was 465 on ET Streets and then went to 448 with the heavy street tires.
Old May 10, 2011 | 04:21 PM
Sidieux's Avatar
Sidieux
That is exactly what I thought, the dynojet numbers should be higher. I am just a little confused as to what it could be. I mean I was thinking 415 at the LEAST. The car has no problems at all so its not like its not running well. I used 7.425 pushrods with the ls7 lifters. I measured and thats what I came up with. I am just a little confused as I didnt even break 400 with that cam on a dynojet, just doesn't make sense to me... I could have sworn I see people with a similar set up make up to 430 with the LS6 heads. I am not too upset as all they are is number, I was just wondering if anyone had seen or know anything I am missing.
Old May 10, 2011 | 04:25 PM
Sidieux's Avatar
Sidieux
My torque is at 348.
Old May 10, 2011 | 06:44 PM
Silnus's Avatar
Silnus
No question you are making more power with the new cam. Sounds like the dyno could be shaky if the standards are the same. You should be around 425 rwhp.
Old May 10, 2011 | 09:38 PM
vettenuts's Avatar
vettenuts
I think your original numbers were high myself. I had a 216/224 cam with headers and Dart heads and made 390 on a Dynojet. Also, was the 216/224 a Crane cam? If so, the ramp rates are slow and if the new cam is an XER then the old numbers are definitely off, especially on a Mustang.
How does the dyno curve look, any dips? The Hardland Sharps can produce valve train issues.
Old May 10, 2011 | 09:51 PM
Sidieux's Avatar
Sidieux
Why would harland sharp cause valve train issues? It was a crane cam it was paired with 1.8 rockers. NO dips at all on the graph.
Also, Vettenuts, what power are you making with your combo? That seems like a nice setup.
Old May 11, 2011 | 05:26 AM
vettenuts's Avatar
vettenuts
The Harlands tend to be a bit heavy and can cause some issues in the upper RPM. It will show on the dyno if you have a problem.
I suspected that the original cam was a Crane. Stick with the HS rockers as the shaft mounting is more stable then the stud mounts (Cranes).
I really think your original numbers are just off base and very high for that cam and Crane rocker setup based on my experience. I ran essentially the same cam with both stock 241 heads and then with Dart 205 heads. My 241 heads setup with the Crane cam was 370 on the Dynojet, the Darts raised this to 395 give or take a couple of hp on the same Dynojet. The Darts are about the same, maybe a teeny bit better than the 243's you have on your car, so the Mustang dyno I would have thought would come in below my Dynojet numbers.
You mention double springs, are these a carry over from the Crane setup? Are they Crane 832's? Do you have the graph? Reason for asking is there were issues with the Crane 832 valve springs and a harmonic right around 6,200 RPM. If you have that issue it will show on the dyno curve. I chased this issue for six months before I found out about the harmonic.
Old May 11, 2011 | 09:16 AM
Sidieux's Avatar
Sidieux
I do have the crane springs on. At 6200RPM the graph is smooth and has no dips, it redlines about 67 or 68ish.
Old May 11, 2011 | 11:28 AM
Sidieux's Avatar
Sidieux
Old May 11, 2011 | 11:47 AM
vettenuts's Avatar
vettenuts
No, that graph looks good. I think the original dyno is suspect based on my results with nearly the same setup (my cam was on a 114.5 rather then the 113) and I wouldn't worry about it. You must feel a difference in the car when you drive it.
Old May 12, 2011 | 01:38 PM
Sidieux's Avatar
Sidieux
So after they finished the tune up the car finished at 394. This seems very low to me regardless of what others are saying. The car drives great, so I guess I will just forget about it.
Old Jul 24, 2011 | 08:27 PM
musicmankeb's Avatar
musicmankeb
Sounds low to me too.
Old Jul 24, 2011 | 11:10 PM
quickc5zo6's Avatar
quickc5zo6
Does it feel any faster?
Old Jul 25, 2011 | 08:27 AM
Ls1Freek98's Avatar
Ls1Freek98
Every dyno reads different than the next. I wouldnt worry about it. Also, its not AT ALL accurate to compare two different setups on two different dynos.
To Dyno after mods...low numbers?
