On previous cars/trucks I have not seen much difference in short times by either launching off idle or brake stalling before launch. However, at the track folks argue one way or another all the time. I will say with my stock converter I did not see a change either way. I just installed my 3200 billet single disk and am curious how you stalled Vette guys are getting the best 60's? Once the weather in TX dropps below boiling point I will get back to the track to test!
I've gone back and forth over the years about which is better as well, flashing the converter at idle or stalling it up as high as it can go along with attempts at some various RPM ranges in between. I have two stalled cars (C6 with a 3200 and a Camaro Z28 LS1 with a 3600) and used to swear that flashing them was the quickest way down the track but that's not always the case now. My best sixty foot in the Corvette came from stalling it up to roughly 2500rpm and letting it rip.
A lot of it will also depend on track prep and just how high you can bring it before the tires start to spin and/or the car starts to push through the beams.
It's going to take some trial & error/experimentation as each car can react differently.
with the above post - mine has a 3000 stall, I get best times flashing it to about 1250 before launch, one of my kids kicks my a$$ with it by brakimg it to about 2800, then letting it go, and my other kid beats me by braking it to about 2000, so you have to experiment with your car on various track conditions to see what works best for you and your car..... my bud called the guys at Precision industries to ask them the best rpm to launch with his Vig 2800, and they told him to flash it to around 1250 or so and let the TC do the rest, and that seems to always work best for him regardless of track conditions....
i brake my vig 3600 to 1750 to 1800rpm resulting in 1.405 best 60 ft n/a consistent low 1.4's and a best of 1.344 60 ft when juice turned on at 4200rpm's
However, I have found lately that by being "up" on the converter, that your (my) reaction time may/has gotten better. If you're just chasing an et, the above thought comes to mind. In a racing scenario, I would recommend being 'up' on it, try around 2k and go up or down from there.
True, sometimes the approach that yields the best 'light' (reaction time) is not the same as the one that provides the best ET/MPH as well.
