New Tires???...haha
On this run, I gave it 1/3 throttle to start, then when I applied the gas, it started to spin, backpeddled, gave it more, it shifted to 2nd, and you can't tell from this angle, but it went a little squirrelly, (spelling?) sideways enough to scare me, but it was over so fast that I just kept it going. Each run I had to back out of at 1 point or another.... and where last years 60 foot times with the same tires were 1.80, this time it was 2.10, only had 3 tries before the rain....
The MT are a tire you can drive on all the time, so no worries there.
Nice job, but you should get to the track more often... LOL
Yes, I hit the limiter. when I viewed the clip in slo-mo, I could see that it jumped a little sideways when it hit 2nd, (real fast), I tried to start out slow but it started spinning, I back-pedalled, hit it again, it started spinning again, hit rev-limiter, then it hit 2nd, jumped a little bit sideways, just enough to scare me, then I kept it down to the end. I was happy with the 124 mph tho..... and you're right, I need practice at the track....badly.....haha
what do u think I would run with the current setup? last year with the same tires, I had a 1.80 60ft time. with the sc, i could do no better than 2.06.... i could only get 3 runs in b4 rain. 373 gears and 2800 stall converter doesn't help with the sc= more spin. lg longtubes into hi-flo cats into borla stingers.....505 rwhp= what ET? did 124.31mph but only 11.833= slipslidinaway....Thanks Huff.
