yeah, I am looking for z06 fronts now, then will get ET Street Radials to go with. Anyone know how much time you can improve drop with skinnies up front?
typically .1-.3 I know that's a pretty big range, but different people set their cars up to better respond to the weight change. Take your front sway bar off too. What is your rear gear ratio?
Get back out there and give'er hell! 11's are right there.
Thanks. Is the sway bar just for weight? Or is there more to it? I also like to road race, and need the front sway bar for that. I'm running 3.15 rear gears right now. Having no traction now, cannot imagine what 3.42 or 3.73 gears would do!
Removing the front sway is for weight transfer. It is hollow and doesn't weigh much at all. So you can just unhook the links and leave it in place.
A good drag radial will solve most of your traction issues - provided the track prep is there. Lots of auto trans guys use the 275/40/17 M/T drag radial. I've had success with he Toyo TQ in the same size. Hoosier makes the same size too, and they hook the best, but they're not really that good on the street.
