Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Quest is finally over!!!!
Old Nov 17, 2011 | 08:53 PM
  #41
Alludc's Avatar
Alludc
Sic run. pretty cool you got to do it next to a civic on crack that made it fun to watch too!
Old Nov 19, 2011 | 09:52 PM
  #42
blownnastyc5's Avatar
blownnastyc5
just curious, what rear gear and tire are you running? I have 3.90's on a 305/35/18 and always hit the rev limiter right at the lights in 4th....
time for a drag set up, not a purdy street set up I suppose
Old Nov 21, 2011 | 05:43 PM
  #43
PRE-Z06's Avatar
PRE-Z06
4.10s and 26x11.50 ET Street squeezed on a 8.5" rim, I'm always a fan of function over looks.
Old Nov 21, 2011 | 07:50 PM
  #44
blownnastyc5
what power are you making, im in the 600 area, and hitting the limiter in 4th at about the 1250ft mark on 26" tires with 3.90's at 130mph
Old Nov 21, 2011 | 08:29 PM
  #45
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Raise your limiter???
7500 rpm. Hehe
Maybe only 7300. You have rod bolts?
I've spun my stock bottom end LS 1 to 7200 more times than I can remember. Might not be the best idea, but it worked for me...
Old Nov 21, 2011 | 09:34 PM
  #46
evo2ls1's Avatar
evo2ls1
I believe in the mid 400's, you need less gear or more tire
Old Nov 21, 2011 | 11:46 PM
  #47
blownnastyc5
yea, I'll keep the limiter at 6800 and go to a 16" wheel with a 28" slick... this was just out for fun to see if I could sneak in 10 sec pass, 11.06 at 131mph right before the track closed after a 11.6 and 12.04 with a 2.6 60ft,lol
cold tracks are hard to leave on with a small sidewall tire...
Old Nov 22, 2011 | 11:09 AM
  #48
PRE-Z06's Avatar
PRE-Z06
422rwhp last time on the dyno. I agree you should run a 28" tall tire with that power and gears. Hoosier makes a 28x11.50r17 that a buddy went 9.7 in his 6-speed with.
