Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Best "drag pack" set up for a C5?
Old 02-02-2012, 12:44 AM
huggerorange73
huggerorange73's Avatar
St. Jude Donor '12-'13
Default Best "drag pack" set up for a C5?
Looking to see what you guys are running in terms of drag wheels....
From mild ( $ ) to wild ( $$$ )
Thanks!
Brackets (04-30-2020)
Old 02-02-2012, 07:35 AM
0Superman09
Former Vendor
Superman09's Avatar
CCW Drag Pack here!
Old 02-02-2012, 09:43 AM
Fartpipe
Fartpipe's Avatar
Draglites are cheapohs. but the lightest option by far.
Cheapies are ZR1 replicas and greg weld or alumastars front runners
Weld RTS's are middle to high end of the road
CCW's are nice and middle to high end.
Highline is probably BOGARTS.
Old 02-02-2012, 02:19 PM
123sugey
Dig
Support Corvetteforum!
123sugey's Avatar
What size rear wheels are those Superman09 ?
Old 02-02-2012, 04:21 PM
mAydAy121
mAydAy121's Avatar
St. Jude Donor '10
My CCW drag pack is retardedly heavy. I'll stick to my Greg Weld's up front and whichever of my various botched together rear sets fit the track that day.
Low end is GTO spares and F-body 16" rears.
Old 02-02-2012, 10:43 PM
pianoprodigy
pianoprodigy's Avatar
St. Jude Donor '12
Bogart D10s here. Insanely light
Old 02-02-2012, 10:53 PM
0Superman09
Former Vendor
Superman09's Avatar
16x10, offset set up for the flares 26x11.5x16 tire
Old 02-02-2012, 11:22 PM
LS1LT1
LS1LT1's Avatar
I also use only C5 rims (both 17s and 18s and both base LS1 and Z06 styles) on the back with GTO spares on the front when I race, but it's not even driven solely by my typically 'budget minded' mentality LOL. I had CCWs and actually sold them to use these type of set ups instead.
Not a C5 of course but this combo works on C5s as well:
C5 17" fronts with C5 Z06 17" fronts:
Old 02-02-2012, 11:34 PM
huggerorange73
Thanks for all the great info!!!! Much appreciated.
More info on this set up please!
Old 02-03-2012, 06:42 AM
paint it black vette
paint it black vette's Avatar
run 5 star fluted bogarts like said before they are light. had ccw's very pretty but not as light as bogarts and a real chore to polish.
Old 02-03-2012, 12:40 PM
RonSSNova
RonSSNova's Avatar
I'm curious what you guys find from going narrow and light on the front end wheels/tires. Assuming you don't go to a taller front that is. (taller front gives a better ET due to more roll out)
The rear portion is obvious due to the change to slicks or drag radials. The best being a radial slick, although I haven't researched sizes there.
Ron
Old 02-03-2012, 02:21 PM
Stevo92z28
Stevo92z28's Avatar
budget drag pack right here and very light as well!
GTO spares with racemaster front runners. Also added a 1" spacer to space them out better. Rears OEM 17" thinspokes. Still have the rears but i sold the gto spares.
Old 02-03-2012, 03:01 PM
pit-man
pit-man's Avatar
That is a good match
Old 02-03-2012, 08:05 PM
algZO6
algZO6's Avatar
Old 02-03-2012, 10:10 PM
4DRUSH
4DRUSH's Avatar
Originally Posted by algZO6
Man, they look really nice.
Old 02-03-2012, 10:17 PM
4DRUSH
4DRUSH's Avatar
Hardcore = spindle kit for 15" rims and modified wheel well for 30" drag radials.
Old 02-04-2012, 10:37 AM
algZO6
algZO6's Avatar
thanks jay. this spring im going to do some tpe fenders with some drag spindles and drop down to a 15. what size and offset are your prostars?
To Best "drag pack" set up for a C5?
Old 02-04-2012, 10:39 AM
dascorcha21
dascorcha21's Avatar
are you using 15" on the front and rear? and do you have to change brakes in the rear or is the spindle kit the only thing really needed to be changed out?
Old 02-04-2012, 12:37 PM
PRE-Z06
PRE-Z06's Avatar
Received 2,054 Likes on 1,306 Posts
Old 02-04-2012, 05:17 PM
4DRUSH
4DRUSH's Avatar
Rear Prostars are 15x10" with 7.5" Backset. (shown in pic)
With 28" 11.5" slicks I'm thinking 6.5" to 6" will fit the flared fenders better. Check back with me when you're ready, by that time I should know.
15's on the front with Strange lightweight brake kit.
(Doug actually has a used brake kit for sale which includes the modified spindles).
http://forums.corvetteforum.com/drag...-assembly.html
For the rear:
The ECS 15" kit comes with Strange lightweight brakes and any rim will fit.
The LG spindle kit allows you to use your stock brakes, but you'll need a spacer & caliber grinding.
Quick Reply: Best "drag pack" set up for a C5?
