Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Need Trans controller for 4L60e
Old Feb 16, 2013 | 12:55 PM
pit-man's Avatar
pit-man
Default Need Trans controller for 4L60e
What are you guys running...what is the best in your opinion from experience ? I would like one that will work on a 4L60e + a 4l80e for the future.
How hard are they to wire up ?
Pitt
Old Feb 16, 2013 | 01:02 PM
pit-man's Avatar
pit-man
I have been looking at US Quickshift 1
Old Feb 17, 2013 | 04:04 AM
RonSSNova's Avatar
RonSSNova
Might get some answers here
I remembered reading it.
http://www.carcraft.com/techarticles...ollers_tested/
ron
Old Feb 17, 2013 | 08:07 AM
pit-man's Avatar
pit-man
ron
Thanks Ron
Old Feb 17, 2013 | 10:00 AM
corvette8189's Avatar
corvette8189
Rpm recommended this
http://forums.corvetteforum.com/c5-p...r-pcs-tcm.html
I'm running it now and works just fine.
Old Feb 17, 2013 | 10:19 AM
pit-man's Avatar
pit-man
How hard to hook up ?
Can you log with HPTuners still ?
Old Feb 17, 2013 | 10:35 AM
corvette8189
Easy to hook up like 7 wires, there harness is universal so there are a lot of wires you don't use.
No you can't with hp tuners, but it has its own data logging software. I would give RPM a call they know all about it.
Old Feb 17, 2013 | 10:55 AM
pit-man's Avatar
pit-man
k..thanks man
Old Feb 17, 2013 | 06:31 PM
RonSSNova's Avatar
RonSSNova
Just curious, why you aren't going to use the pcm to run the trans?
Conversion from a stick and don't want to dick with finding and installing the correct harness?
ron
Old Feb 17, 2013 | 07:30 PM
pit-man's Avatar
pit-man
ron
Ron,
I just had my tranny rebuilt and went with a B&M shift kit, a 9.5" TC (3600SS from Yank), 100 mm Maf (from SD Tune) and back to my original cam from Pete and new tune. That is a S-Load of changes at once. When I went to the track, something was telling it to shift out of 1st to 2nd gear at 8 mph then back to 1st at 28mph.... then ran fine for the remainder of the track. We worked on it all day with nothing changing those weird shift points.
Fast forward to today, I transferred some old trans data to my tune and got it to work correctly, but short shifting into 2nd at 5100 rpm and into 3rd at 5700 rpm. Just some fine tuning to do now to adjust to redline of 6150 rpm. Sure feels good to get it working on the stock PCM once again. Had the Hoosiers at 10psi hot and still had no traction till third gear hit.
Old Feb 17, 2013 | 09:04 PM
evo2ls1's Avatar
evo2ls1
truck looks even faster on the street!
Old Feb 17, 2013 | 09:12 PM
RonSSNova's Avatar
RonSSNova
Ron,
I totally spaced that out, sorry.
This is a drive by wire vehicle, right?
I wonder if the addition of the MAF had something to do with it?
Ever seen these spreadsheets?
http://www.hptuners.com/forum/showthread.php?t=27981
As I tuned my MAF curve, the trans quit doing the 2-3 shift. So used this spread sheet to pick mph and rpm and bingo.
Might not be even close, but worth a look compared to your current settings.
Ron
Old Feb 18, 2013 | 06:54 AM
pit-man's Avatar
pit-man
I hope the track shows good results.
Ron
The Maf was added after 2 years of the trans running perfect, but that was in my thoughts as one of the problems. It is cable operated, not Driveby. I still have no clue as to what was causing the shift to 2nd at 8mph. Crazy !! I still wonder if not getting any traction thru the gears was keeping it from doing the weird shifts. Back to the track to be sure.
Thanks for the spread sheets Ron, I will compare to my settings.
Old Feb 21, 2013 | 08:08 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
We use the PCS for all the 4l80 cars.
Old Feb 22, 2013 | 07:06 AM
pit-man's Avatar
pit-man
Thanks Fran,
I think I got it shifting thru the stock PCM once again. Hoping to make the track next Friday to finish shift points.
Old Feb 22, 2013 | 02:31 PM
pit-man's Avatar
pit-man
The Brick on Bogarts
To Need Trans controller for 4L60e
