Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Backhalf numbers
Old Jun 1, 2013 | 03:41 AM
RonSSNova's Avatar
RonSSNova
Default Backhalf numbers
I ran the car tonight and tried a new approach to tame our slick track.
I left at 2000 and got 1/2 throttle as it moved out then matted it. No tire spin. Even netted a 1.59 60ft. Car would be bad *** on a dead hook track.
Anyway, on that run, it went 7.14 @ 98.8 in the 1/8 mile, and 11.18 @ 121 in the 1/4 mile.
Thats only 22mph on the back half which just seems wrong.
So, you A4 guys who run in this range, what are your back half numbers?
I was reviewing my good runs from last year, and it was 23 on the back half, not quite as fast in the 1/8 mile.
We did have a smidge of a head wind, and I don't run skinnies up front...although I do have some.
Just curious.....
FWIW...my son went to the track 60 miles south, ran 12.2 which is 2 tenths better than he has run at my track....and they sprayed throughout the evening. You can bet I'll go down and try a REAL dragstrip soon!
Ron
Old Jun 1, 2013 | 08:32 AM
Rob Petyo's Avatar
Rob Petyo
You lost me Ron. One mph in the back half? I don't see the problem, what am I missing?
I think you need to run that beast in New Jersey where EVERYBODY runs personal bests ! !
Rob
Old Jun 1, 2013 | 09:08 AM
Tar Heel's Avatar
Tar Heel
Ron,
The last time we were out we only run low 12s and 110mph in the 1/4 so I don't know if this will help you or not but we pick up 23mph in the second 1/8. 1.59 60' is pretty impressive rolling into it. Our best is 1.60 and we dead-hook. New 295/50/16 Hoosier drag radials are here so when the new wheels arrive I'm anxious to try them and see if we can dip into the 1.5x range. Oh yeah, I do run skinnies ... I picked up 3mph from those over the OEM wheels.
Old Jun 1, 2013 | 10:37 AM
RonSSNova's Avatar
RonSSNova
I think from the 1/8 to the 1/4, it should pick up at least 24 mph.....not 22mph.
I may put the skinnies on tonight, or just run the Nova.......
Old Jun 1, 2013 | 10:50 AM
Rob Petyo's Avatar
Rob Petyo
air conditions could have been a little different too, I lost 3 mph from Nov to when I ran in March. March was just crappy air in comparison.
Have you ran with the skinny's? You are knocking at 10's door
Old Jun 1, 2013 | 12:50 PM
RonSSNova's Avatar
RonSSNova
I've only tried the skinnys once, didn't seem to make a diff, but diff day so who knows?
I'll air em up and try tonight. They are M/H bias....would rather have radials....oh well. The rims are GTO spares.
Old Jun 1, 2013 | 01:14 PM
GARY2004Z06's Avatar
GARY2004Z06
Ron- Would not worry about your back half numbers all that much. The bias ply tires are substantially lighter and should help.
Good luck.
Old Jun 1, 2013 | 02:31 PM
RonSSNova's Avatar
RonSSNova
Good luck.
Boy are they. You can put them on with one hand! Also, I actually have run my best numbers with the smaller Hoosier 245/45 on thin spokes vs. the 275/40's on Z06 wheels. They are also lighter....maybe I'll try that combo tonight.
Old Jun 2, 2013 | 01:56 AM
RonSSNova's Avatar
RonSSNova
Well, with the skinnies, the car did mph better, but I was tweaking the tune. About 1 mph. ET was no better than yesterday.
I noticed something interesting....the left lane showed 25.5 mph on the back half, the right lane showed 23mph.
Left lane 97 mph, right lane 99mph. 660ft.
I think the clocks are all messed up, as is the starting line. I never even tried leaving full throttle, and still spun bad on 2 runs....
All runs over 122 after I found what it liked for AF ratio, which btw is 12.2:1
Ron
Old Jun 2, 2013 | 09:22 AM
speedraider's Avatar
speedraider
for me its 30mph
Old Jun 2, 2013 | 10:49 AM
pit-man's Avatar
pit-man
Just curious.....
Ron
Ron,
I found a run real close to yours and my back half is right there with you. This is my Auto, 3600 stall
11.164 @ 120.28
1.611 - sixty
7.107 @ 97.41
Pitt
Old Jun 2, 2013 | 12:01 PM
RonSSNova's Avatar
RonSSNova
Originally Posted by pit-man
Ron,
11.164 @ 120.28
1.611 - sixty
7.107 @ 97.41
Pitt
Good news! Thanks. I really need to go to a real dragstrip!
I may head south next Friday.
Ron
Old Jun 2, 2013 | 12:18 PM
pit-man's Avatar
pit-man
Ron
Good luck without NOS...it is sooo frickin hot here. Running NA is no fun in the summer
Old Jun 2, 2013 | 12:24 PM
ZZOOM06's Avatar
ZZOOM06
Ron,
I typically pick up 30+mph on the back half, but my car is a stick with 3.42 gears and a 416 stroker. I run a CCW drag pack with 16x11.5x26" ET streets and Firestone bias front skinnies. If I only had to drive 60 miles to get to a good track, I'd do it in a heartbeat! Go there and report back, I bet you'll be pleasantly surprised!
Jimbo
Old Jun 2, 2013 | 12:51 PM
RonSSNova's Avatar
RonSSNova
I would even make the drive with my budget drag pack on the car. Sad fact about the C5, you can't pile 4 tires/wheels in it and change at the track.......Well, maybe if I took the pass seat out.
I'll check the forecast for this Friday.
You stick guys back half quite differently. And of course you have a lot more hp than I do.
I am so gun shy of my track, I probably miss the only chance at a full throttle leave on the first pass when there is a little prep. But the car is violent when it blows the tires off, and I like my diff in one piece.
I walked out and checked the start line last night....they seem to forget to spray where the rear tires sit! Gads.....
I actually offered to give the track manager $20 to let me prep the right lane for myself....he just laughed.
Last night, I drove home on the freeway......the drag pack messed up the traction control system....I forgot to turn it off....and with the fronts being slightly taller than the rears.....well, the DIC lit up and the car decided 38mph was my top speed....rather freaked me out!
I sure wish there were a 27" bias street slick out there, but there just isn't!
Ron
Old Jun 9, 2013 | 05:12 PM
PRE-Z06's Avatar
PRE-Z06
On more than one occasion I've hauled drag pack and a passenger to the track over an hour away, people gawk when they see me unload lol. Are you making a shift between the 1/8 and 1/4, also is your converter locked? To make comparisons with the skinnies, make a pass without and then swap them on the same nite as that will lessen the variables and make you a believer I've also run across tracks that the timing equipment wasn't equal between the two lanes and that is frustrating. Good luck next time!
PS are you running a vararam?
Old Jun 9, 2013 | 08:16 PM
RonSSNova's Avatar
RonSSNova
I'm in 3rd before the 1/8 mile. I have a Yank single disc, so no locking in high gear.
I hear you on the skinnies. They would fit easily in the car to try at the track.
The car does have a vararam.
Of course last night I went to watch my son spin the tires in his S10....and it hooked excellent 4 of 7 passes. His best 60ft was 1.67....the vette would have hooked too. They actually prepped extra good for an electric car making passes.
Figures huh?
Ron
To Backhalf numbers
Old Jun 10, 2013 | 02:10 AM
Corvette0096's Avatar
Corvette0096
Mine did 27.9 on the back half last night.
Old Jun 10, 2013 | 02:14 AM
RonSSNova's Avatar
RonSSNova
Yeah, Sideways!
Old Jun 10, 2013 | 02:22 AM
Corvette0096
Yeah, Sideways!
Yah that was fun.
