Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Old Feb 20, 2015, 06:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
Print Wikipost
remove front sway bar?
Old Jun 17, 2013 | 07:22 PM
Tar Heel's Avatar
Tar Heel
Default remove front sway bar?
The car is apart for a cam/UD pulley/valve spring and header install and today I removed the front sway bar to get to the balancer. For those of you that drag race ... do you leave the sway bar off for better weight transfer? We used to do this on every car that we raced in the past but I've never worked on the C5 suspension before. Will leaving it off help? It has skinny M&H's on the front and we rarely (if ever) drive it on the street so it's not like we'll be carving up corners any time soon. The shocks are stock but I'm going to add QA1s on the front soon.
Thanks.
Scott
Old Jun 17, 2013 | 07:57 PM
dankhts's Avatar
dankhts
I'm soon to try that myself at the track and see how it works out..I'm a bit more than a tenth away from 10s, maybe that along with some skinnies will make it happen......we used to do it "back in the day" for weight transfer and traction, but these vettes are pretty much 50/50 so I don't know how much it would help weight transfer or if they need it....some of the 9 and 10 second guys around here do and some don't .....most are dead hooking anyway and say there's no need....
Old Jun 17, 2013 | 10:59 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
For a drag race application, there is no need for the front sway bar.
It doesn't weigh much, but every bit helps.
It does help a bit with weight transfer.
I haven't had a front sway bar on any of my Vettes since my first track visit 6 years and 600+ passes ago. I see no difference on the street at all, but I don't carve canyons at all.
Old Jun 17, 2013 | 11:05 PM
RonSSNova's Avatar
RonSSNova
It's easy to get off, as Cap said, doesn't weight much at all. I guess the question is, does it limit front end travel at all?
I haven't tried it either.
Dead hook? What's that?
Ron
Old Jun 18, 2013 | 07:49 AM
GARY2004Z06's Avatar
GARY2004Z06
Remove it.
Old Jun 18, 2013 | 08:03 AM
Tar Heel's Avatar
Tar Heel
Easy enough. I just won't put it back on. Ok, here's the next question. What about removing the paper element from my Vararam? Again, it's most likely going to morph it's way into a 100% race car. I have to do a retune for the cam, headers, taller tire, etc. so that would be a time to address the increased air flow. Any gains to be had here?
Old Jun 18, 2013 | 01:55 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
Leave it off!
Old Jun 18, 2013 | 03:08 PM
Tar Heel's Avatar
Tar Heel
Originally Posted by DragMan
Leave it off!
So do NOT replace the paper element and get it tuned accordingly for the increased air flow? And try to avoid any dust storms?
Old Jun 18, 2013 | 03:53 PM
PRE-Z06's Avatar
PRE-Z06
Yes real men who drag race use panty hose...seriously though if it's a drag only car then I'd leave the front sway bar off as it definitely doesn't hurt.
Old Jun 18, 2013 | 04:40 PM
pit-man's Avatar
pit-man
Norman (Stanger) said removing the filter was a solid tenth for him every time. I removed mine last time out and gained 1+ mph...ran 132mph for the first time in 4 years, in worse air.
Old Jun 18, 2013 | 05:11 PM
PRE-Z06's Avatar
PRE-Z06
My results have been the same
Old Jun 18, 2013 | 06:39 PM
Tar Heel's Avatar
Tar Heel
Thanks guys. Glad I asked! So no sway bar and no air filter element when it all goes back together. Also, I talked to a guy that runs a stock shortblock LS1 in his Stock Eliminator car and he goes 0.06 quicker running 6 quarts of RedLine 5wt oil. I'm going to try that as well. We're trying to squeeze out every last tenth as we shoot to run a second under our 12.45 index.
Old Jun 18, 2013 | 09:45 PM
Rob Petyo's Avatar
Rob Petyo
I remove the front sway when I race but install it back on for use on the street. My "98" handles much tighter/safer on the street with it on...
Old Jun 18, 2013 | 11:28 PM
RonSSNova's Avatar
RonSSNova
Vararam came with a paper element? Mine had a destroyed whatever stock element, so I replaced with a permanent K&N from a TR6. It's glued in.....
If the paper restricts airflow, I would think recurving the MAF would be necessary?
Ron
Old Jun 19, 2013 | 08:32 AM
Tar Heel's Avatar
Tar Heel
Originally Posted by RonSSNova
Vararam came with a paper element? Mine had a destroyed whatever stock element, so I replace with a permanent K&N from a TR6. It's glued in.....
Ron
It may not have been a "paper" element; that was my mistake. I was referencing the stock green one it came with. Yes, I would think the MAF would need tweaked. I have to get a retune anyway for the headers, taller tires, air pump removal, cam, etc. so it would be a good time to do it.
Scott
Old Jun 20, 2013 | 09:11 PM
98tadriver's Avatar
98tadriver
I gained a track proven, time and time again, .06 sec by pulling my filter from the vararam. just make sure your airbox is clean
To remove front sway bar?
