New Tune and Dyno
408 ci 10:5.1 compression 470 RWHP 478 RWTQ,1 7/8s LTs w/ full 3'' exhaust and 3'' X-pipe w/ duel ele-cut outs,RPM Stage 5 6-speed transmission,CCW 505As Rims ,Targa top Conversion.All in this Little Light *** FRC The Predecessor to the ZO6.
Anxious to see if turndowns are worth that much on my little 346.
LQ9 iron block that has epoxy coating
Eagle Forged Crank
Eagle H-beam rods
JE Forged Pistons
Ported hi volume oil pump
Duel Roller timing chain
Comp cam 228/232 - 595/602 - 115+4
CTS-V roller lifter
Comp Cam One piece push rods
WCCH Stage II P&P L92 Heads Duel Springs for 650 lift
ARP Head Bolts, cam bolts
SLP Underdrive pulley
L76 intake w/P&P LS2 TB
New LS3 injectors, adapters and harness plugs
Vararam B2 AIR intake w/85mm MAF and vararam air bridge
New NGK plugs and GMPP Red Plug Wires
Rev-X-treme Oil Catch Can
New radiator
Racetronix fuel pump and harness upgrade
Yep i can feel the 30 extra power...
Eagle Forged Crank
Eagle H-beam rods
JE Forged Pistons
CTS-V roller lifter
New radiator
Nice flat torque curve you got there too!Jimbo
[IMG]
[/IMG]Input welcome !!
my 382 wanted to scream this morning in the cool, crisp 50* air
