Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Bolt on 01 + Cam prediction?
Old Sep 20, 2013 | 01:03 AM
C 5's Avatar
C 5
No Time!
Default Bolt on 01 + Cam prediction?
Hey all, So as of now I have Headers+full exhaust, SLP Blackwing, tune, and nitto 555r DR (305s), I plan on getting a cam installed in less than a month, TSP Torquer 2 (113 LSA) and n2mb 2 step/wotbox.
What are the times people usually run with these mods/similar cam? (the cam going in is a 232/234 .595"/.598 cam)
On street tires when all I had was a Blackwing CAI, I ran a 12.5 @ 114 and I spun bad on that run and short shifted to second. Now that I have DRs I am interested what results I can net with this cam and the Kooks (1 3/4 Long tubes). Thanks
Old Sep 20, 2013 | 08:12 AM
Tar Heel's Avatar
Tar Heel
We have an '04 coupe with similar mods however our cam has to have stock factory lift and duration for class rules. Through a Yank SS4000 and 3.90 gear (and 28" tires) it made 372 at the wheels. I'm going to think you should be around 400 but I'm not a 6-speed guy so I don't know how that affects everything. We went 12.2 before the headers and cam so based on that I would guess, depending how you hook, shift and the air you should be in the 11.75 range.
Scott
Old Sep 20, 2013 | 09:37 PM
C 5's Avatar
C 5
No Time!
Scott
Hopefully so, 12.5 pass was on tires that were long gone, and have been sitting outside for years. I am pretty sure if I happened to have DRs at that time I could of gotten low low 12s or high 11s. I think if I hook good with them in my current stage I can be in the 11s for sure.
However I hope I can do better than 11.75 with the cam and my mods.
To Bolt on 01 + Cam prediction?
