First time out procharged zo6
Nov 10, 2013 | 07:34 PM
Finally got a chance to take it to the dragstrip today.
60... 1.684
330... 4.570
1/8... 6.901
mph... 107.24
1/4... 10.612
mph... 132.76
Details on the car are:
2003 zo6/ stock bottom end.
Procharger p1sc 3.6 pulley
custom blower cam
lg longtubes, x pipe, b&b catback
e85, 80lb injectors, aeromotive 340 fuel pump, kb boost a pump
centerforce dual friction clutch
ccw dragpack with 315/45/16 mickey thompson drag radials
Nov 10, 2013 | 09:36 PM
Nice times especially for the first trip!
Nov 10, 2013 | 11:55 PM
Very good times for the 1st trip out! Its atleast got 10.40s in it from the 60' alone... Mph for 10.20s.. That's if you can keep the driveline parts in it..
Keep practicing, you're doing great!
Nov 14, 2013 | 01:08 AM
How much power did you lay down?
Nov 14, 2013 | 09:37 AM
107 in the 1/8 is great for your setup
Nov 15, 2013 | 11:12 AM
Nice!!! X2 on how much power the car made on the dyno.
Nov 18, 2013 | 07:57 PM
Made 630 at 5500. Tuner didnt want to turn it any harder seeing as how its the stock motor.
Nov 18, 2013 | 08:01 PM
Quote:
Originally Posted by
ajrothm
Wanting to get some slicks and go back out
Nov 20, 2013 | 12:05 PM
Makes me want to jump on board with a Procharger setup!
Nov 28, 2013 | 12:23 PM
03TORCHREDZ
60... 1.684
330... 4.570
1/8... 6.901
mph... 107.24
1/4... 10.612
mph... 132.76
custom blower cam
First time out, you make me sick. How did you launch it? Did you lift to switch gears?
Nov 29, 2013 | 07:39 PM
Launched it at about 3500 slipping the clutch just a little and yes i lift between shifts. Still have the stock tranny and rear end. This was just my first time out in this car. Ive had a couple of other c5s that I've been out in.
Dec 1, 2013 | 02:58 PM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Very nice results, they will only get better!
Thanks,Matt
Dec 1, 2013 | 03:01 PM
Congrats.
Dec 30, 2013 | 10:35 AM
Did you change gears at 5300 since the tuner didn't tune past that rpm?
Dec 30, 2013 | 09:31 PM
danieloneil01
No, was changing around 6800-7000.
Feb 6, 2014 | 03:59 PM
03TORCHREDZ
Maybe I miss read. Did you say the tuner left engine management stock after 5.3k.
Feb 7, 2014 | 06:24 PM
Nice times
Feb 9, 2014 | 08:57 PM
540i 6spd
No, its not stock, just didnt want to pull it any higher with the stock bottom end. It does absolutely fine.
Jun 5, 2014 | 12:18 PM
03TORCHREDZ
Im totally at a loss with this thread. Your tuner wouldn't make a pull on a dyno past 5500 rpm because he says its not safe on a stock bottom end but you run the car up to 7000 rpm at the track. So your ok with turning 7000 rpm under the load conditions of the street on a guessed tune from 5500 rpm and up. Wow
Jun 5, 2014 | 03:21 PM
