Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Numbers seem wrong for newly built ls1, Help!!
Old Mar 12, 2014 | 06:19 AM
CSRelentless's Avatar
CSRelentless
Navigator
Default Numbers seem wrong for newly built ls1, Help!!
99 corvette with these mods:
Ls6 243 heads, comp cam xer273 224/230 581'/588' 114lsa, lsx FAST intake, slp longtubes, bbk 82mm throttle body, air intake, trans has 3200 stall with shift kit, 3.42 gear
Took it to get it tuned and it only made 355rwhp.
I've seen same setups on here with same cam and heads making over 400rwhp, my question is do the numbers seem right for my setup,something seems off.
Old Mar 12, 2014 | 01:31 PM
RonSSNova's Avatar
RonSSNova
What kind of dyno was used?
Old Mar 12, 2014 | 01:46 PM
mchicia1's Avatar
mchicia1
1) It's an auto car on a dyno, take it to the track to get a real performance benchmark
2) Why are you using that weird throttle body? Put a 90mm LS2 TB on that thing.
Old Mar 12, 2014 | 02:02 PM
tlove32's Avatar
tlove32
Stalls and Dynos are not a match made in heaven. Take it to the track and you should be pleased
Old Mar 18, 2014 | 06:09 PM
Anthraxmm's Avatar
Anthraxmm
Yeah your not getting an accurate reading. Take it to the track and see what mph it runs. My just bolt ons ls1 did 355rwhp, but a six speed so no slip.
Old Mar 19, 2014 | 02:48 PM
Tar Heel's Avatar
Tar Heel
Was it a Mustang or DynoJet? IIRC the Mustangs read much lower.
We made 372 with our stock lift/duration Stocker cam and that was through a Yank SS4000 on a DynoJet. I would think with a H/C you should have been significantly higher.
Scott
Old Mar 19, 2014 | 04:32 PM
04tripleblkcoupe's Avatar
04tripleblkcoupe
My 408 A4 build with a SS4000 stall and 3.42 gears made on conservative tune 471 rwhp and 453 torque. making 605 hp at the flywheel.
Callies Compstar Crank 4340 4.00" ARP Main Bolts
Rods 6.125 ARP bolts
Pistons 4.030 -3cc
247cc Fully CNC Ported Intake Runners
84cc Fully CNC Ported Exhaust Runners
Spring Kit Rated To .675" Lift
68cc CNC Machined Chambers
2.120" Intake / 1.600" Stainless Valve
Hyd Roller Cam 239/242 .649/.610 111.5 LSA
Comp Roller Rockers Arm Ultra Gold 1.72
7.450 Chromemoly Pushrods
Nick Williams 102 TB
Fast 102 Intake
Fast Fuel Rails 60lbs injectors
4L65E Level V RPM tran
Yank SS4000 Stall
Stage II differential, C6 Z06 left and right axles, micropolished gears, HD clutches and springs,
gear ratio: 3.42
ECS trans brace
Old Mar 19, 2014 | 08:01 PM
Mikey K's Avatar
Mikey K
I made 381hp and 381tq with a blackwing, American racing long tube with hi flow cats and I believe the same cam not sure since I got the car with the work done already but those are the specs DRM gave me.
So through an auto with a stall that's not bad. Like has been said. Bring it to the track and see what it does.
Old Mar 20, 2014 | 01:30 AM
quickc5zo6's Avatar
quickc5zo6
I made 348 rwhp back in the day from a 98 Camaro that had hand ported 241 heads(they weren't the 98 castings), 222/226 cam, slp long tubes, borla cat back, FLP built 4l60e, 3.42 gear, yank ss 4000 stall converter, lid, ls6 intake, ported throttle body, slp MAF and im sure there are a couple little boltons i left out.
Best time was 11.6@116 with 245/50 bfg drag radials, with 1.60s 60ft, leaving out the hole off idle, then punching it. Take dyno numbers with a grain of salt. The drag strip is the best dyno.
EDIT: There was a C5 on the same dyno that day getting tuned by the same tuner with a heads and cam package similar to mine, but smaller stall speed that made 2-3 more rwhp than me.
Old Mar 22, 2014 | 01:03 PM
PRE-Z06's Avatar
PRE-Z06
Was the converter locked? What wheels/tires do you run? I assume you have a 78mm Fast with that TB?
Old Mar 27, 2014 | 07:59 PM
540i 6spd's Avatar
540i 6spd
My guess is the following is holding you back "bbk 82mm throttle body"
Old Mar 30, 2014 | 12:11 AM
baxsom's Avatar
baxsom
Are you saying that because it is a BBK or because it is larger than oem? I mean I dynoed at 450rwhp with a stock throttle body on a FAST 78 so Im a little confused why the throttle body would hold something back unless just because it is a BBK a company not known for quality.
To Numbers seem wrong for newly built ls1, Help!!
