Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Good or ? Tuning
Old Apr 10, 2014 | 08:46 PM
123sugey's Avatar
123sugey
Dig
Default Good or ? Tuning
Very interesting read
http://www.fuelairspark.com/fas/gm-l...html/?AID=3236
What do you Do you guys think ?
Old Apr 10, 2014 | 10:53 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I've heard nothing but good things about the FAST EFI system. That said, if I was going to go with a stand alone controller, I'd use the Holley EFI system. I think the support is better and it has greater flexibility with the various add ons.
I know some have wired the holley system into the existing PCM, so all the normal car functions work, and the holley controls the engine. That's the **** right there.
I do not believe the fast system will control DBW. Nor can it handle 2 WB, or 8 EGTs.
The base Holley system won't either, but the dominator system will. Of course, it's about $2800 (or more) once you pick all the features you want to use.
Good luck with your research.
Old Apr 10, 2014 | 11:38 PM
LSOHOLIC's Avatar
LSOHOLIC
I'm with Pete......
Holley Dom system has so many advantages.....and yes you can "piggyback" it to the factory ECU (as to allow gauge cluster,HUD..etc operations).
But the biggest advantage IMO is.......Holley and Davis Tech collaborating on a plug-in play traction box...and that folks...is a huge plus. Self learn, or non-self, adjustments made with-in 1/8th of a driveshaft revolution.
Dennis @ Moore racecraft in NJ is the man to see, he worked with Holley on developing this product.
Old Apr 11, 2014 | 10:16 AM
123sugey's Avatar
123sugey
Dig
Thanks guys I have more reading now lol
Old Apr 11, 2014 | 10:32 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
Are you on YB?
Plenty of good reading in the LSX and tuning section of that site. If you can ignore the chest pumping and miscellaneous bickering...
Old Apr 11, 2014 | 10:43 AM
123sugey's Avatar
123sugey
Dig
Originally Posted by Capthuff
Are you on YB?
I'll check out the LSX section on YB thanks
Old May 7, 2014 | 05:44 PM
PRAY's Avatar
PRAY
Dude, is your motor done or what?
Old May 7, 2014 | 06:20 PM
123sugey's Avatar
123sugey
Dig
No not happy at all…...
Old May 7, 2014 | 08:36 PM
PRAY's Avatar
PRAY
Dang bro. Wish I was home when it happened. I would have taken care of it for you. Was the block cashed out. I am looking for a LS3 block right now.
Old May 7, 2014 | 08:49 PM
123sugey's Avatar
123sugey
Dig
The head got beat up some and was not sure on the block so I just bought the LSX454 figuring it would be quicker to get installed vs tearing engine out and apart, sending to machine shop etc etc. I should have bought Robz's destroked 388 and had his buddy install.
I'm in Honduras again but will be back to FL again pretty soon. I'll check out the short block
To Good or ? Tuning
