The c6z pinion support will work in the c5 diff, it’s much stronger than the c5 support and helps to keep the trans output shaft from flexing and breaking, I’m running c6z pinion support, output shafts and clutches in my diff, also have ecs brace
Hi there, do you have any part numbers or a diagram explaining what parts these are? I just broke the same parts and i dint know what to do and want to get the car on the street asap.
