Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Light Flywheel
Old Jun 14, 2004 | 02:14 PM
R6T2Corvette's Avatar
R6T2Corvette
Default Light Flywheel
Eckler's sell a 12.5 aluminum flywheel for LS1's that I am considering in order to reduce tire spin. Does anyone know what a stock LS1 flywheel weighs? Has anyone had any experience with running a light flywheel? Advantages? Disadvantages? I would assume that the lighter flywheel would reduce inertia and make it easier to get off the line. (but you know what they say about assume?
Old Jun 16, 2004 | 06:29 PM
Brannon's Avatar
Brannon
Default Re: Light Flywheel (R6T2Corvette)
I believe the stock Flywheel weighs 37-40 pounds. I have the aluminum flywheel and can say that my wheel definitely don't spin as much. Especially when shifting into 2nd. Before, my tires would spin quite a bit shifting had into 2nd. Now, not much at all, and my car dyno's at 349rwhp and 368rwtq.
I will say that starting out in 1st is little more difficult. The car shutters a little from time to time, if you're starting off slow.
Old Jun 16, 2004 | 07:54 PM
HalfMoon's Avatar
HalfMoon
the LS6 flywheel that comes in the package everyone buys weighed in at 25 pounds here. I'll bet the one your looking at is the Fidanze aluminum one. Check the pricing your seeing with Ecklers with others on the forum. The Fidanza goes for about $300ish, I got mine on a sale a couple years back for my Camaro and it was cheaper. The Fidnaza weighs 12.5 pounds, and is 1/2 the weight of the stock flywheel.
Old Jun 16, 2004 | 09:36 PM
R6T2Corvette
Default Re: Light Flywheel (Brannon)
Thanks Brannon. Do you have the 12.5lb flywheel? Did you notice an improved throttle response? Your HP and TQ numbers look great. Do you think that the lighter flywheel contributed to these numbers?
Old Jun 16, 2004 | 09:39 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
They are about 11 or 12lbs lighter and are very responsive however you need to learn to drive all over again to avoid heavy chatter.
Old Jun 16, 2004 | 10:38 PM
R6T2Corvette
Default Re: Light Flywheel (lager99)
The chatter was mention by Brannon in this thread who put the light flywhell in his car. My 62 has a tube chassis and with the LS1 and Keisler TKO600, weighs just 2775lbs. My understanding is that the lighter the car, the lighter the flywheel and vice versa. From the reasearch that I've done so far, if the flywheel is too light for the car, clutch/car will tend to shutter/chatter when starting out with too low an RPM. I'm hoping that someone else out there can verify this.
Old Jun 16, 2004 | 10:49 PM
lager99's Avatar
lager99
St. Jude Donor '06
The light flywheel does not have enough enertia to propel the car slowly.
Old Jun 17, 2004 | 08:27 AM
Brannon's Avatar
Brannon
Thanks, I do have the 12.5lb flywheel. LG installed it when putting in my Spec II clutch. If I'm not mistaken, the dyno improved by about 7hp. The car does climb though the rpm faster with improved throttle response.
Old Jun 17, 2004 | 10:35 PM
night feeder's Avatar
night feeder
i have finally gotten used to mine
Old Jun 18, 2004 | 06:25 PM
z-u-later's Avatar
z-u-later
Default Re: Light Flywheel (night feeder)
My 02 Z06 stock flywheel cane in at 26.5 lbs & the aluminum replacement came in at 13.5 lbs
The power goes right to the wheels..
Old Jun 18, 2004 | 10:44 PM
steveNY's Avatar
steveNY
Default Re: Light Flywheel (z-u-later)
I have the SPEC III with the Aluminum flywheel, I have small amount of chatter. Seems as though there are times when taking off it's not too bad at all, then there are times if you catch it just right the entire car shakes violently. I'm getting better at keeping the chatter to a minimum. One final note, from the discussions I have seen. If you have a good installer & you break it in slowely the chatter should be to a minimum. Overall, I'm use to it and it's not a major issue.
Old Jun 21, 2004 | 10:03 AM
Nikita's Avatar
Nikita
How long did it take you to get used to it?
Old Jun 21, 2004 | 05:25 PM
R6T2Corvette
Is clutch chatter a problem? What about wheel spin? Did you notice that it was easier to get it off the line without so much wheel spin? If you had to do it over, would you change anything (a bit lighter flywheel, a bit heavier?)
Old Jun 21, 2004 | 05:27 PM
R6T2Corvette
I'm not familiar with "spec ii" clutch. What is this? Would you recommend this with the lighter flywheel?
Old Jun 21, 2004 | 05:30 PM
R6T2Corvette
Default Re: Light Flywheel (steveNY)
Thanks Steve. I'm not familiar with the terms "spec II" or "spec III" clutch. Can you fill me in? Are these GM clutches or an after market piece? Do you recommend the spec III with the lighter flywheel?
Old Jun 23, 2004 | 03:35 PM
BossHogg528's Avatar
BossHogg528
St. Jude Donor '06
I had an aluminum flywheel on my last car - didn't notice a visible performance gain, but I absolutely loved the sound of the free-reving engine!! I haven't picked one up yet for my '01, but I will sooner or later.
Old Jun 23, 2004 | 05:03 PM
JC-5's Avatar
JC-5
Default Re: Light Flywheel (BossHogg528)
2 months and about 1500 miles and the new clutch/aluminum flywheel chatter is almost gone. You do have to learn how to drive it all over again, but in the end, it's worth it
To Light Flywheel
Old Jun 23, 2004 | 06:48 PM
JR04Z06's Avatar
JR04Z06
Default Re: Light Flywheel (JC-5)
what do you mean by "learn how to drive it again"? ie:fast/slower clutch release, high/lower rpm,
Old Jun 23, 2004 | 07:23 PM
JC-5's Avatar
JC-5
Default Re: Light Flywheel (JR04Z06)
You need to bring the revs up a little more on launch.
Old Jun 24, 2004 | 06:24 PM
steveNY's Avatar
steveNY
The SPEC III is an aftermarket clutch. I had the installer put in a new clutch with a aluminum flywheel (the whole package). It does Rev quicker. When shifting it feels like stock except there is a little chatter sometimes starting off light on the peddle. The spec III claims to handle approx 600 HP. The difference between the SPEC II & III is the plate material which relates to how much HP the clutch can handle.
