So how fast is my car on top end? Calculation question. . .
Re: So how fast is my car on top end? Calculation question. . . (PaceThis)
Dunno- but you're going to get 1,000 different answers as everyone seems to have their own calculation when figuring theoretical top speed
Well if you're in an auto it's 186 in 4th gear@6000 RPM if you tach it to 6500 rpm you can do 202. With a 6 spd in 5th gear you can do 188@6000 RPM and 203@6500 RPM. At 190 mph it takes 290 HP to the rear wheels to overcome wind resistance, at 200 it takes 340 hp at the rear wheels. This doesn't factor in rolling resistance, nor weight, only wind resistance. In 5th gear you put ~375 hp to the ground so you could possibly acheive the 202 mph mark if you had plenty of time to get there. All figures located on smokemup.com
Re: So how fast is my car on top end? Calculation question. . . (Demented)
hi there, here's a couple of fomulas hope it can help:
table #1
ne: which is engines rpm
pe: engines brake power (kw)
we: angulars velocity (1/s)
me: engines torque
pe=pe max [(ne/ne max)+(ne/ne max)^2 - (ne/ne max)^3 ]
pe max= maximum power ... ne max: rpm for that power
we=2bi ne / 60
for all rpms
me= (pe/we) * 1000
table #2:
then there's another story
note: do the same for all gears 1-6
ig*id= initial gear ratio * final drive gear ratio
nw= ne/(id*ig)
ww= 2bi nw/60
mw= me*mech trans efficiency*ig*id
fw= mw/rw
vc (km/h) = rw*ww*3.6
you can get rw with this formula:
rw=(d/2*25.7)+(a*b*0.9)/1000
ex.:
if u r using P285/35ZR-19 Goodyear Eagle F1 SC
then rw= (19/2 * 25.7)+(0.35*285*0.9) /1000 = 0.33
then draw this with FW in the vertical axis and VC in the horizontal axis.
then lets say you got a maximum Vc = 400 km/h
do this for the last table
tabl #3:
in the left
20km/h, 50 km/h, 100 km/h tell you get 450 km/h (more than the maximum vc u got)
then each speed (Vc in km/h) / 3.6 = m/sec right?
now bring Ra (air resistance) which = Ac*C*Vc^2
Vc in m/sec
Ac= Width of the car in meters * Height in meters * 0.79
C= drag coefficient
then bring Rolling resistance which = G * F
G=Weight (kg) * 9.8 (s gravity)
F is for the coefficient for the road.
Ex. asphalt and concret roads = 0.014 - 0.018 for the excellent conditions while 0.018 - 0.020 for satisfactory conditions
note: Rr is constant for all speeds
then bring Ra+Rr for all speeds
draw a curv for (Ra+Rr) with the same graph that u draw the gear curves, as you can see the rr+ra curve did contact with some gears.
the maximum vc with the contact point is your maximum theoretical speed.
ex1: conatct points where in 5th gear at 290 km/h, and ith the 6th at 330 km/h
then your top speed is 330 km/h
ex2: contact where in the 5th gear at 316 km/h, and 6th gear 294 km/h
then you top speed is 316 km/h in the 5th gear
you must use 3.7 gears or 3.9 gears rather than 3.1 gears
hope that helps,
ahmed
PS. i'm sorry PaceThis, i couldn't do it for u because i've final exams these days
[Modified by Q8Y, 12:59 AM 6/17/2004]
[Modified by Q8Y, 1:00 AM 6/17/2004]
table #1
me: engines torque
we=2bi ne / 60
for all rpms
me= (pe/we) * 1000
table #2:
nw= ne/(id*ig)
ww= 2bi nw/60
fw= mw/rw
ex.:
tabl #3:
in the left
Vc in m/sec
C= drag coefficient
hope that helps,
ahmed
Re: So how fast is my car on top end? Calculation question. . . (Q8Y)
table #1
me: engines torque
we=2bi ne / 60
for all rpms
me= (pe/we) * 1000
table #2:
nw= ne/(id*ig)
ww= 2bi nw/60
fw= mw/rw
ex.:
tabl #3:
in the left
Vc in m/sec
C= drag coefficient
hope that helps,
ahmed
table #1
me: engines torque
we=2bi ne / 60
for all rpms
me= (pe/we) * 1000
table #2:
nw= ne/(id*ig)
ww= 2bi nw/60
fw= mw/rw
ex.:
tabl #3:
in the left
Vc in m/sec
C= drag coefficient
hope that helps,
ahmed
St. Jude Donor '03 & '05
Ok you lost me right here?
"then draw this with FW in the vertical axis and VC in the horizontal axis.
do this for the last table"
Ok you lost me back at the top but I thought I was keeping up!
Try this link:
http://home.nc.rr.com/jbolton/asim.html
I have a very easy method to calculate tp end speed. First
is to calibrate the speedometer and then drive at 3,000 RPM in 5th and check your speed should be about 95 at a guess. Just double the speed for 6,000 RPM which should be 190. This is just a guess. You need to go out and do this to find out.
1998 Lingenfelter Twin Turbo C5 top speed is 203.1 -- you will be less than that
Ooops... must have been an early version, or I just don't know what I was reading Yep, 230 or so MPH, but that's with 1100 hp.
I'll still say less than 203.1
EZ
You take (me) and put (me) in (UR) car and the answer will be in your face in 5 mins.
J/k
I did 188 in mine at 6000 rpms with 540RWHP M6!
More than that I run out of road and Baaallllllllsssss!!!!!!
J/k
Originally Posted by 3RD-INF
Take the darn car out and give her hell. Thats the only way you will ever know.
If you add some HP you have to use it do some road racing (on closed road) and you will see what your top speed can beThere is a good one in Nevada.
