I installed the Kooks headers with the high flow cats this weekend, took about 12 hours and I have broken knuckles galore. I hope your sitting down for this....I gained a whopping 5 HP and 8 lbs of torque.
Disappointed is an understatement, I'm flat out pissed. Any ideas?
The tuner was stumped also.
Vararam, Stingers, Kooks=379HP 366 Torque
I installed the Kooks headers with the high flow cats this weekend, took about 12 hours and I have broken knuckles galore. I hope your sitting down for this....I gained a whopping 8 HP and 10 lbs of torque.
I don't really want to throw more cold water on you, but here is my experience with headers. I have added headers to several muscle cars back in the 60s. They look very cool and sound very cool, but I can't honestly say that I felt any noticeable difference in power. With the headers completely uncorked, which would obviously be illegal, I did feel a little more power. After spending that kind of money and the hassle of installation and tuning you would think you would get more. It is experiences like that that have soured me on most simple bolt-on after-market equipment. It is just not that easy to get significant power increases.
If headers/cats add 20-30rwhp, 10rwhp may be from longtubes, and 10-20 may be from replacing the dirty cats.
You probably have a low mileage late model Z06. The Z06 manifolds flow better than standard C5 manifolds, and newer cats flow better than high mileage cats.
I also agree with mdhmi, did you have it dyno-tuned? Headers will scavenge the cylinders better than stock manifolds (therefore the hp increase), which means less exhaust (with no fuel) remains in the cylinder and more fresh mixture (by default rich to compensate for remaining exhaust) comes in. You're probably running rich.
I see no info about your car. The Vararam caused a loss of power on my car. The new headers can only make it run leaner. Also, your headers won't help scavenge much with a cam ground on a 117lc.
Better post your A/F, spark tables so they can be reviewed by the forum. For what its worth, I still don't believe most of the posts about those headers. From the way my own car runs, I'd be curious how it runs with a stock exhaust and cats.
The temperature was 8 degrees less than last time and the humidity was the same. Also, in reality the headers gained 5 HP, we took the air filter out for the last run to get up to 8. I can live with the lousy HP number but I was expecting much more torque than 10.
The headers actually made it run richer, once we leaned it out we got the pulls below:
Wow. So we're looking at the blue (RunFile_009) and green (RunFile_014) lines? And it's been tuned? Wow, very close curves. I'd also feel disappointed, since nothing obvious is wrong.
Here is the sheet with just the vararam and Stingers.....
Oh well, if it performs better on the track I'll be happier, thats what really counts....Tomorrow night we'll see...............
That sucks I picked up 31 peak hp and 26ft/lbs of torque and lots under the curve with no A/F tuning. See chart. There's got to be something going on with your deal, good luck.
Well my track results were mixed, I gained 2 mph in the 1/8th and nothing in the 1/4th. Et's were about the same. I seem to have felt a slight hesitation when shifting into 4th, but only 4th, I think that is where I lost my 2 mph. Knock retard? Too much timing?
LG discussed in one of his installation posts a problem called false knock. Don't remember the details, but he did state that he had to tune it out some how. I believe it was the knock sensor picking up the normal header sounds and pulling timing, but not sure on this. Might be worth looking into though as your situation seems somewhat unique compared to what others have reported. Good luck, hope you get this figured out.
something not right...we all know Kooks are a quality header...most folks are realizing a 15 to 20 rwhp gain, good SOTP feel and positive track results... keep digging for answer...good luck...
Unfortuneatly, I have not had the chance to dyno, before or after, the Kook's, but they mad a HUGE difference for my car. It pulls much harder through every gear, especially around 3-4k rpms. I am anxious to get on a dyno and see where I am at and what I can get out of tuning! Good luck with you situation!
I got the almost the EXACT same numbers from the kooks, and high flow, lemme get the dyno paper....
