Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
vararam
Old Oct 18, 2004 | 02:41 AM
Ramsie C5's Avatar
Ramsie C5
The install really isnt as hard as it seems. Its the first thing I ever installed on ANY car, it just takes time.
I love mine though, I wouldnt have any other intake.
Old Oct 19, 2004 | 11:57 AM
shurite44's Avatar
shurite44
The hardest part is the fog lights, they are a bear. Keep close track of all the fasteners as you take them off it can be confusing. I also recommend taking a pic of your intake before you disassemble it that way you can use it as a referance as you start to button things up. good luck it took my cousing and I about 6 hours and it was tedious but not rocket science.
Old Oct 19, 2004 | 12:39 PM
TLewis4095's Avatar
TLewis4095
Originally Posted by NotRiceAnymore
A friend of mine with an auto 04 vette went to the track after installing it, and proved that you actually lose 3 to 4 10ths off your 1/4mile time. he is a shop owner up north (www.precisiontuning.com) and knows his stuff. if he says it works, it will definately be under the hood of my car.
I have to question this as , We race a team of 3 race vehicles, 1 a bolt-on only C5 and 2 rear engine alcohol dragsters.
The only way this guy lost ET is if the coupler was loose or his tuning that far off.
All the cold air induction mods show excellent results but in real on track testing with DA and fuel levels listed (do a search in the archives for the thread) we found the Vararam to exceed all we have tried in ET improvment. I also agree with others here that we saw most improvment down track when our MPH was over 50.
www.emilylewisracing.com
www.flacorvettechallenge.com
Old Oct 19, 2004 | 12:41 PM
TLewis4095's Avatar
TLewis4095
On the install we completed it in app 2 hours with 2 crew and all tools needed. No problems with any part other than I had to get a new shroud to replace the cut one from the Breathless unit.
Old Oct 19, 2004 | 02:03 PM
shurite44's Avatar
shurite44
If someone installed a vararam 1 or 2 and lost time in the qtr something is wrong with the vehicle. I would guess something else caused this not the vararam. I really can not see just this bolt on effecting tuning enough to cause it to lose power either. For the thread starter you should know this thing has a very sound engineering concept and I have personally used it and it works. Please email me with any questions I would hate to see you lose out on a very good bolt on due to misimformation.
Old Oct 19, 2004 | 04:29 PM
C5JONNY's Avatar
C5JONNY
I think he means lost time for example 13.2 to 13.0.
Old Oct 19, 2004 | 04:32 PM
shurite44's Avatar
shurite44
I think you are right, that makes more sense with the rest of the post.
Old Oct 19, 2004 | 04:44 PM
TLewis4095's Avatar
TLewis4095
That would make sense. I'm just not used to it being worded that way.
Old Oct 20, 2004 | 11:38 PM
NotInTheHerd's Avatar
NotInTheHerd
Email me. I have a Vararam and red smooth tube for sale. Will explain when I reply.
smithga59@hotmail.com
Greg
Old Oct 23, 2004 | 10:21 AM
David Gordon's Avatar
David Gordon
I went froma backwing and a Heads and cam motor with 414 rwhp and ran a best of 12.6 @ 112
New setup Vararam with a new heads and cam 449 rwhp and ran
a best of 12.5 @ 115
I dont think it is as good as it advertises.
Old Oct 23, 2004 | 05:43 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Originally Posted by gmosley
does a vararam really work or is it just another hyped up product
any advice well taken
if theres something better feel free to suggest
gmosley,
According to our dyno testing/tuning sessions, there wasn't another intake that performed like the Vararam, PERIOD! The Vararam provided more rear wheel horsepower and torque over any other aftermarket intake system and kept the MAF intake temp readings 20 degrees cooler which makes the car run even stronger and more efficient.
We recommend the Vararam systems very strongly and have installed a ton of them so far. The installation is the only challenge, but once you get it on, get ready to have fun!
Shawn
