75 Convert - AC/Heat - repair
Hi Guys:
Finally getting back into my Vette. Car is a 36K, sort of original. I've done the complete interior, brakes, exhaust, carb, etc, etc, but now in need of a operating HVAC system. Up until this year the Heat at least worked but the Blower has now quit working. Also, went to charge the AC system with R12 (I know a guy) and the main compressor hose has a 2" hole in it. So this is what I'm thinking: Fuse is OK on the Blower motor, going to replace the Blower Motor Resistor and Motor assembly for good measure. Obviously need to replace the Main compressor hose, but how the heck do you get the hose off the Expansion valve? Looks impossible! Any thoughts or experiences are greatly appreciated. Should I be upgrading anything else while I'm at it? Looking to get back on the forums with pic and progress with the car, as I decided no Harley for now and focus on my Vette. Shes been in my family for 43 years! Going to rebuild the front end after the HVAC is tackled. Thanks for reading and offering any suggestions Tom |
Tom...
I have to say this ... just from my experience... I'd replace the unit with a vintage air unit... it'll work much better than the factory unit and be less cost than fixing the original unit. Now if you are head strong on fixing the original unit... post back... I've got tons of experience in this unit. Willcox |
With three daughters I may be on the path of least resistance. I’ll look into the vintage air units. |
Still wondering if I really need everything being the car only has 36k original miles. But I do want to move forward And not keep throwing money and time at a unit that’s going to just keep breaking down. |
I recently purchased a 75 convertible and I'm planning on getting the AC up and running as well. Mine is missing the dryer and the condenser. The original hoses are all still there and the compressor. Where does one find information on this Vintage Air system?
Just a heads up on this and I'll add a bit more.... the VIR equipped cars can't handle the 134a Freon so if you repair it you'd have to use R-12 which is very costly.
It's just my opinion and experience that a repaired factory ac system will cool but it's not going to cool as well as the Vintage Air or other aftermarket systems. If installed properly the VA system will freeze you out. Willcox |
Originally Posted by Willcox Corvette
(Post 1598094338)
Originally Posted by 1975Stingray
(Post 1598094386)
Thanks! Can you make a suggestion on the Vintage Air kit? Thanks
You should also check out this thread... https://www.corvetteforum.com/forums...tion-tips.html |
(Post 1598094585)
I'd call Vintage air direct and get one that would be your best bet. Then save all the old stuff in case you ever decided to go back or if someone would come up with something to replace the VIR drier on this system...
Looking at the VA system instructions have me a little nervous! I've done a complete interior upgrade on the car, but this project seems slightly more intense! Question on the complete system ( Looks like $ 1480 ISGRET) do you need to replace/upgrade the wiper vents? I have an AC car thus the vents are already in tack.
Thanks for any words of encouragement. |
I think I’m up the the task, but one question to those who have installed the VA Kit, do you need to take the dash out? Please,please, please say no!!! |
(Post 1598108135)
I think I’m up the the task, but one question to those who have installed the VA Kit, do you need to take the dash out? Please,please, please say no!!! If you are worried about how to get the other pads out... go to this link... it'll take you step by step on the right and the center dash... but use the other one for the left pad... http://repairs.willcoxcorvette.com/w...structions.pdf Willcox |
https://www.vintageair.com/instructions_pdf/564174.pdf
https://www.vintageair.com/instructi...561174-PCZ.pdf These two kits are our GEN IV surfeit series, one is with factory air and the other is w/o factory air this will give you some insight to the install process |
I installed VA System on my 75, ( Hi-Lites here,,) https://www.corvetteforum.com/forums...-on-storm.html
Really not that difficult, saying that I remember seeing something about an extra brace under the dash, for a convertible. You May want to check into that. Have a Great Day, Bill |
