Results and Repair for "warrenmj" Engine Problem Post
"warrenmj" had previously posted a thread under the heading "Engine Problem:"
https://www.corvetteforum.com/forums...problem-2.html There were a lot of guesses as to what the problem could be, but the only way to figure it out is with a good, personal physical inspection of the car. So Mark trailered the car up from Colorado Springs this morning so we could take a good look at it. He arrived at the Corvette Lounge & Workshop this morning at 10am sharp with the car and beer: https://cimg4.ibsrv.net/gimg/www.cor...2b454489e8.jpg Offloading the car went smooth - the engine would start, but it was making noise... https://cimg9.ibsrv.net/gimg/www.cor...67093c7bc1.jpg All set up on the lift for diagnosis: https://cimg8.ibsrv.net/gimg/www.cor...88d42f3889.jpg A quick visual inspection showed that the harmonic balancer outer ring had slipped and shifted rearwards over 1/8", so the balancer needs to be replaced. IMPORTANT NOTE: GM used different balancers over the years with timing lines in different locations. Any time you are going to swap the balancer, do timing chain work, swap timing chain covers, or swap timing pointers, it's a REALLY good idea to verify the actual Top Dead Center (TDC) position of the crankshaft, and to mark this actual position on the harmonic balancer. In the case of Mark's engine, the original 1966 engine had been swapped out with an L79 clone, with the later model timing chain cover. This engine will need the 1969+ balancer in order for the timing lines to be right. Here the fan and waterpump pulley have been removed, and an air ratchet is used to remove the 3 pulley attach bolts. A 1/2" drive impact was used to removed the balancer center bolt: https://cimg3.ibsrv.net/gimg/www.cor...8d2204be97.jpg Bolts and pulleys removed, and balancer is ready for removal. The rearward shift of the outer ring is now clearly visible: https://cimg8.ibsrv.net/gimg/www.cor...02cbca9b18.jpg A good balancer removal tool is essential for easy removal of the pressed-on balancer. It fits easily onto the balancer in the Corvette engine bay: https://cimg3.ibsrv.net/gimg/www.cor...c3510bc20e.jpg A few turns of the tool with a ratchet and deep socket... https://cimg6.ibsrv.net/gimg/www.cor...7a5dcf39b4.jpg ...and the balancer is off the crank snout: https://cimg3.ibsrv.net/gimg/www.cor...556182236c.jpg It is now really obvious where the noise was coming from: The slipped outer ring was rubbing on the timing chain cover just below the timing tab, and it was hitting the raised welded part of the tab: https://cimg2.ibsrv.net/gimg/www.cor...a535664535.jpg Lots of rubbing marks on the balancer with heat discoloration from the rubbing friction: https://cimg9.ibsrv.net/gimg/www.cor...1f54ee400c.jpg This balancer is shot... outer ring has shifted noticeably rearwards, and it's highly likely that it has also rotated, making timing verification impossible: https://cimg1.ibsrv.net/gimg/www.cor...d53d7795b8.jpg https://cimg1.ibsrv.net/gimg/www.cor...4f845de4fa.jpg A new 8-inch balancer is on order, and the car will be re-assembled and checked out in just a few days. Good thing Mark caught this when he did - these things do a lot of damage if they come apart at elevated rpm... :cheers: Lars |
Awesome update and diagnostics. Ed |
Lars, what is your reasoning for replacing the balancer vs rebuilding it by the likes f Damper Dudes in CA. I'm here to learn. :shrug: Dennis
Originally Posted by Bluestripe67
(Post 1598685030)
Lars |
Lars:
THANK YOU for your informative and excellent posts here on the CF. :thumbs: We can all learn and benefit from them. I'll heft a few bottles of Miller Lite tonight in your honor. :cheers: Larry |
Thanks Lars. Great meeting you this morning. I knew waiting for you to get an opening in your schedule was going to be worth the wait! I was just getting off I-25 after driving from Lars house back to Colorado Springs when he called and told me what the problem was and the fix. I had the original (I think it was original) balancer replaced in March 2012. Here is the post I started on that problem and how lucky I was not to have it completely disintegrate at a higher speed, https://www.corvetteforum.com/forums...some-help.html
Here is a 2012 photo of the crack in the balancer.https://cimg5.ibsrv.net/gimg/www.cor...ebc924d9e3.jpg |
Originally Posted by Powershift
(Post 1598685105)
I'd feel real bad if you hurt yourself drinking that stuff... Mark dropped off some good beer here when he dropped off the car, so in the interest of your health, I should send you a plane ticket so you can sit here in the Corvette Lounge and drink good stuff with proper supervision... :cheers: Lars The Corvette Viking Lounge, where good beer is used to build fast Corvettes: https://cimg9.ibsrv.net/gimg/www.cor...fcb3fc30db.jpg https://cimg9.ibsrv.net/gimg/www.cor...a2b6279a0e.jpg ...and, yes, there is a stripper pole in the lounge, too. It's off to the left out of the picture in the open area for the dancers. I don't want them hitting their heads on the chainfall. |
Excellent diagnosis and follow up, thanks for sharing. By the way, I like good beer also! |
Originally Posted by emdoller
(Post 1598685018)
(Post 1598685105)
Lars: THANK YOU for your informative and excellent posts here on the CF. :thumbs: We can all learn and benefit from them. Larry
Originally Posted by Factoid
(Post 1598685312)
Lars |
Great report and work. The beer is well-deserved.
Do these things gradually/incrementally give up or does some event cause them to give up at some accelerated rate?
I was puzzled by the oil change time/space coincidence. |
I've seen a lot of these fail - it's a very common problem. Every one that I have seen fail has happened suddenly and immediately with no apparent underlying cause or event promoting the failure. Once a balancer has suddenly slipped or shifted (like Mark's did), it will quickly get worse up until it actually comes apart. When they come apart, it's brutal and violent - the last one I saw come apart put a friend in the hospital with a shattered foot from the shrapnel coming out from underneath the parked car he was working on. A short time before that, a Vette that had been in my shop blew the balancer at freeway speed, and the force of the explosion sheared the water pump off the front of the engine, and balancer pieces bouncing back up off the pavement broke the bellhousing in 3 places, and sheared the headpipes off the exhaust manifolds after cutting the hood off the car. This stuff is no joke. Luckily, they usually tend to make a bit of noise (from hitting other parts) before going into catastrophic failure. The oil change and balancer failure were completely coincidental, and were not related events in any way.
Lars |
Is that side stepping a common thing to inspect for?
I'm moving inspecting mine to top of the work plan as we speak. I've seen the rubber part aged but was unsure at what point was too far to have a safe margin. Thanks for bringing this forward. |
Originally Posted by lars
(Post 1598685282)
Larry -
I'd feel real bad if you hurt yourself drinking that stuff... Mark dropped off some good beer here when he dropped off the car, so in the interest of your health, I should send you a plane ticket so you can sit here in the Corvette Lounge and drink good stuff with proper supervision... :cheers: Lars The Corvette Viking Lounge, where good beer is used to build fast Corvettes: https://cimg9.ibsrv.net/gimg/www.cor...fcb3fc30db.jpg https://cimg9.ibsrv.net/gimg/www.cor...a2b6279a0e.jpg ...and, yes, there is a stripper pole in the lounge, too. It's off to the left out of the picture in the open area for the dancers. I don't want them hitting their heads on the chainfall. Would it be better if I drank "Dixie" Beer (brewed bottled here in New Orleans) instead ?? It was legend for decades here in the Deep South.....and is now available once again. Except they no longer use Mississippi River water in the recipe.....so the flavor is not as harsh. :rofl: In prior days I had a commercial beer dispensing setup at the house, so I have tasted a lot of suds. But time and old age has slowed me down to occasional Miller Lite in cans.:leaving: Pretty sad, I guess. :cheers: Larry EDIT: Many years ago, just after college, I took an engineering job in SE Texas. I can still remember marking beer runs to west of Dallas to bring back cases of Coors. :D Once dated the daughter of the South Texas Distributor for Lone Star Beer. That was good times also. |
I’m sorry, but that’s blasphemy. When you’re in SE Texas you drink Shiner! https://cimg1.ibsrv.net/gimg/www.cor...9e0336f60.jpeg |
(Post 1598685987)
I once dated the daughter of the South Texas Distributor for Lone Star Beer. That was good times also.
(Post 1598686118)
The Lone Star sign hangs above the bar: https://cimg8.ibsrv.net/gimg/www.cor...4c6fc3d419.jpg If you don't like what's on tap, open the kegerator door and grab a Shiner...: https://cimg8.ibsrv.net/gimg/www.cor...b07923ab98.jpg :cheers: Lars
Originally Posted by Dennisscars
(Post 1598685957)
I'm moving inspecting mine to top of the work plan as we speak. I've seen the rubber part aged but was unsure at what point was too far to have a safe margin. Thanks for bringing this forward. Lars |
(Post 1598686118)
Great cars, great minds, great beer... what can I say..? :cool:
There was a discussion not long ago about dampers. This is the reason I say no cheap aftermarket dampers. They really don't meet any testing minimums they just make them as cheap as possible and spit them out. They last past warranty so the manufacturer is out of the picture. I only use GM or ATI, stock engine GM race ATI. |
Originally Posted by warrenmj
(Post 1598685179)
