How many are you waiting for the 10 speed?
Old Mar 26, 2017 | 09:24 AM
DogTag-C7R's Avatar
DogTag-C7R
I don't understand the original post, or reasoning very well. Even if it fit.....why would anyone wait on driving this car a couple of years? Then they may never do it so you might as wellwait for the c8..since the C7 is old news......but you won't want the first year model so you wait for the electric model.....it's a marginal difference so I wouldn't let the model get older and older......jump in and live a little
Old Mar 26, 2017 | 11:39 AM
2fastnow's Avatar
2fastnow
Look at the stated fact about size right under the color drawing cutout,
The new 10-speed automatic has essentially the same physical dimensions as existing 6- and 8-speed counterparts. It features a gun-drilled main shaft.
https://saemobilus.sae.org/feature/16AUTD07_02
Old Mar 26, 2017 | 11:37 PM
24/Eray's Avatar
24/Eray
Originally Posted by glass slipper
Because HP is what accelerates a car and the power band of the LT4 is narrow. The M7 and A8 are close ratio transmissions to keep the LT4 in its power band, more gears always benefit engines with narrow power bands and close ratio transmissions. The M7 loses to the A8 in a quarter mile/stoplight-to-stoplight race because 1st gear in the M7 is very low numerically...it was forced into that because of the close ratio gear set used. The A8 loses to the M7 in roll races/road races because the 4th-5th shift causes a large drop in RPM just at the speed where it hurts the most...as you increase speed, the gear ratios need to get closer and closer.
The A10 has a numerically high 1st gear similar to the A8 and 10th gear is slightly lower numerically than 8th gear in the A8. That means the gears are closer together and the huge drop in RPM between 4th and 5th gear are gone. The performance with the A10 would be significantly better than the A8 or the M7 no matter what race you're participating in.
true when jumping from a 4spd to an 8spd.
100% more gears.
8 to a 10 spd. Is a 25% increase. Which is not much given the spreads. The 650/650 make it even less so unless you're talking about drag racing and looking for .05 improvement and maybe a mph.
think of 8spd like a 3400 stall and the 10 like a 3600. Sire it'll be quicker but not earth shattering.
gm having enough trouble with 8 gears. Let's see how this plays out. Imo same size casing means even smaller parts to allow for more gears. That's a scary enough proposition.
and why didn't they offer it in the ZL1 1LE?
Old Mar 27, 2017 | 12:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by skank
With a Torque power band as wide as the Mississippi on the LT4 why would anybody want more gears???
Simply not needed
Old Mar 27, 2017 | 07:16 AM
skank's Avatar
skank
Narrow Power band on a LT4 ???? It has 457 ft/lbs of torque at throttle tip in and is broad all the way up to it's max of 650 ft/lbs. That is massive !! The Ferrari 458 has 398 ft/lbs of torque at it's peak. The Ferrari engine would be considered narrow under your analysis.
http://www.chevrolet.com/performance...gines/lt4.html
http://www.lsxmag.com/news/lt4-engin...50-horsepower/
Old Mar 27, 2017 | 08:50 AM
Jus Cruisin's Avatar
Jus Cruisin
I'm not. Once I get bored with my Z06, I'll be done with Corvettes. Kind of like the old TV show "Eight is Enough", I'm on my 8th Corvette and it will be replaced with something yet to be determined.
Old Mar 27, 2017 | 10:24 AM
CPhelps's Avatar
CPhelps
An automatic transmission doesn't have discrete gears like a manual transmission, instead using a series of gear sets and clutches to achieve the desired ratio. Both the 10R90 and the 8L90 have 4 gear sets, but the 10R90 has 4 rotating clutches compared to the 8L90's 3. Both have 2 braking clutches. So it's not like they are shrinking the existing 8 gears to cram 2 more in, they just have to package an additional rotating clutch. Therefore I would not draw any conclusions about strength from the number of forward gears.
Old Mar 28, 2017 | 03:31 PM
glass slipper's Avatar
glass slipper
You have a very clear misunderstanding about torque and HP. As I said in my post, HP is what accelerates a car, not torque. FYI, the proper term/dimension for torque is LB-FT which is a force in pounds multiplied by a lever arm in feet. FT/LB is a lever arm in feet divided by a force in pounds. The Ferrari 458 also has a redline of 9000 RPM, remember HP is torque multiplied by RPM divided by constant...the more RPM you have, the more HP you make. The Ferrari also has a 5.14:1 rear axle ratio and 3.08 1st gear to multiply its torque to be the same at the rear wheel, torque of the engine by itself doesn't tell the whole story. The Ferrari has similar performance and a much higher top speed...just a different way to achieve the same thing. It has a lower peak HP but it's power band is wider, it hits peak HP at 8300 RPM and holds it out to redline. GM wouldn't have used a close ratio transmission if the LT4 had a wide power band, they did the same thing on the LS9. The Ferrari 458 uses a wider ratio transmission with its wider power band.
If you believe "massive" torque is the best, you need to swap a Duramax diesel into your Z06...it has 800 LB-FT of torque!
Old Mar 28, 2017 | 03:53 PM
glass slipper
100% more gears.
There will be a significant difference in 5th gear acceleration with the A10, much more than .05 seconds. The A8 has a huge drop n RPM after the 4th-5th shift that puts it way down on the power curve at the worst time...the rate at which you add kinetic energy/HP increases as speed increases, the 4-5 shift is done at over 100MPH.
As CPhelps stated, the A10 uses the same number of gear sets as the A8 and one extra clutch pack. It has two sets of "nested" clutch packs to provide more room for the additional clutch pack, it will be just as strong if not stronger than the A8. I haven't heard of any problems with "structural" failures of the A8, please enlighten us.
The ZL1 1LE is a track oriented car with low production numbers and a market of hardcore racers who think a manual transmission is the only transmission that should be in a "race" car...it's a marketing thing. The overwhelming majority of those people would be surprised to find out they would be faster with the A10. The A10 is in the regular ZL1 which has the same 650/650 HP/Torque as the 1LE variant, what makes you think it would fail in the 1LE car and not the regular ZL1???
Old Mar 28, 2017 | 10:31 PM
2fastnow's Avatar
2fastnow
Don't quote me but they changed the rear/gears on the ZL1 to 331 gear instead of whats a normal ratio like 373's. I don't know as you tech guys do about what they put in automatic's so forgive me.
Now that changes the equation too but I suspect it's to do with longevity of drive train parts more than anything else.
Old Mar 29, 2017 | 08:42 AM
skank's Avatar
skank
Torque vs power explained
http://www.epi-eng.com/piston_engine...and_torque.htm
Old Mar 29, 2017 | 08:48 AM
skank's Avatar
skank
According to GM, the LT4 offers 457 lb-ft of torque just off idle and twists the crank at 625 lb-ft as quick as 2,800 rpm. It also maintains 90 percent of its peak torque from 2,500 to 5,400 rpm. For comparison, a Ferrari V12 produces 28 percent less peak torque at a much higher 6,000 rpm , even though it offers more total horsepower. The LT4 also crushes a Porsche Turbo S engine’s peak levels by 90 horsepower and 134 lb-ft of peak torque.
“Torque is the pulling power of an engine and the LT4’s abundance of it at every rpm in the engine’s speed range helps the Z06 accelerate quicker and respond nearly instantaneously,” adds Jordan Lee, chief engineer for small-block engines. “It’s the very definition of power on demand.”
Old Mar 29, 2017 | 11:39 AM
AzDave47's Avatar
AzDave47
The A10 was jointly developed with Ford and GM so who knows what tradeoffs were made that may/may not allow it to fit the C7? I have heard the A10 is 1/4" longer than the A8 and that there is some minor interference to making it fit in the C7.
Do you have the length of the A10? Everything GM has put out says the A10 is the same length and fits in the same space as the A8. The problem with the A10 being used in the Corvette right now is it isn't a modular transmission, it doesn't have a separate bellhousing from the transmission case like the A4, A6, and A8. Your 4L80 conversions are made difficult because that transmission has its roots in 1960's technology with an addition using 1980's technology to add overdrive, it's physically a very large transmission. The 4L80 is an extremely strong transmission because technology in the 1960's said to make everything bigger to make it stronger, it's a very large transmission physically compared to modern day transmissions. The 4L80 is also very inefficient, they require significantly more HP to drive them than modern day transmissions.
While I hope GM makes the A10 modular, it seems they would've made it modular from the beginning to save investment in new casting molds just to put it in the Corvette. I think it's unlikely to happen but I can still hope...
Old Mar 29, 2017 | 11:53 AM
Speedforhire's Avatar
Speedforhire
If you saw the episode of IGNITION where Randy tested the ZL1 M7 against the ZL1 A10 at Willow you saw that the M7 beat it.
Just sayin!
Old Mar 29, 2017 | 12:05 PM
  #35
davepl's Avatar
davepl
There's a strange and spooky dude on here that is adamant the LT4 needs more gears because peak RPM happens too soon after peak horsepower. Then he'll go on about how stupid you are for not understanding his theory, which he treats as fact. I'm not going to engage, I have no interest in discussing it with him... he's on my ignore list and shall stay there.
Naturally the most acceleration will be had by operating the motor at peak horsepower (ala what a CVT would do if programmed optimally), but we have, as you not, such a broad torque curve that it doesn't seem like we should have to be shifting a great deal. There's a benefit to be had with more gears, I just don't know how significant it is.
I'd be curious to see what the difference is between the 8L90E and a powerglide but I think Desktop Dyno only supports 4 or 5 gears at most. Still might be an interesting experiment.
If you really want to see the basic math for "what generates the most acceleration at a given speed", this guy walks you through it. Ignore the trolls, stick with math! It's for CVT transmissions, but the math preamble is the same.
Old Mar 29, 2017 | 12:15 PM
  #36
2fastnow's Avatar
2fastnow
It takes around 100 HP to turn the supercharger on the Z06 so apples to oranges comparing how the Ferrari makes speed.
Old Mar 29, 2017 | 01:07 PM
  #37
AzDave47's Avatar
AzDave47
Power numbers were at the crank, which is net power after driving the SC, so NO.
Old Mar 29, 2017 | 09:35 PM
  #38
jaden61's Avatar
jaden61
2017 C7 of the Year Finalist
Old Mar 30, 2017 | 06:19 AM
  #39
Jus Cruisin
^^^^ Exactly! At least for me.....
