EFI swap/ Fuel sender option.
Old Jun 15, 2017 | 07:51 PM
Vaipulu's Avatar
Vaipulu
74 Corvette / sbc. Im going to go with a Fitech setup. I really would rather have an in tank fuel pump. Inline is an option I'd take as a last resort. Can I use a 82 crossfire fuel sending unit and 255 walbro (or oem alternative capable of 58 psi max) and will that be a direct fit for my 74 gas tank location? I see that newer c3's have a top mounted fuel sender.
Basically, can I stick a Newer C3 fuel tank into my 74 and it bolt up in place of my stock gas tank? Oem fuel pump suited for the application?
Any idea that get me out of buying a efi gas tank? Or even better using my stock tank?
Old Jun 17, 2017 | 12:42 AM
MN80Vette's Avatar
MN80Vette
I installed a FAST EZ 1.0 in my '80 with an in-tank Walbro 255 and '82 sender modified for a 3/8 return line required for the FAST EZ EFI.
Let me know if you want more info.
Old Jun 17, 2017 | 01:33 AM
Unforgiven1's Avatar
Unforgiven1
Fitech makes a couple of different surge tank setups, there is one that you can feed with your stock pump.
Old Jun 17, 2017 | 01:45 AM
carriljc's Avatar
carriljc
Default where is the sender on a 74?
I installed a Bronco fuel pump in my 68 and I am still using the original fuel level sender installed on the bottom of my tank. I used a Bronco fuel pump because I used to own a 90 Bronco and I knew what it looked like, it's a canister pump assembly, and the fuel returns to the canister.... I have never lost suction (unlike my old inline pump for my Holley pro-jection which used to lose suction whenever I took a corner fast with less than 1/4 tank).
If I were to do it today I would use an 82 sending unit holder instead of doing all that fabricating..... but I'd still use some sort of canister pump to avoid the losing-suction issue.
If your 74 has a large fuel access hole then you have many options.
Some pictures here.
https://www.corvetteforum.com/g/album/6185062
Old Jun 17, 2017 | 10:11 AM
60 SHARK's Avatar
60 SHARK
I also wanted in tank pump in my 75, for my FiTech, I think tank is same in yours, I also wanted to keep original sending unit, and no new holes in my tank,
I have more pics on a post, I'm not sure how to get you to them,,,,,teddy
Old Jun 17, 2017 | 11:17 PM
Vaipulu's Avatar
Vaipulu
This This This!!!!! You can send a link, this is exactly what I'm looking for.
Old Jun 17, 2017 | 11:48 PM
60 SHARK's Avatar
60 SHARK
Ok, great,,,,PM me and I will help you all I can, ,,,teddy
Old Jun 18, 2017 | 01:48 AM
LT1M21Vette's Avatar
LT1M21Vette
You can post the link. Others might be interested...
Old Jun 18, 2017 | 07:43 AM
60 SHARK's Avatar
60 SHARK
I would like to, I just learned pics, I haven't figured out how to get that to work, sorry,,,I'll have my kids help me when they come over,,,,I did it only a few weeks ago, no I can't remember, ,,
Old Jun 18, 2017 | 09:37 AM
'75's Avatar
'75
I found it.
https://www.corvetteforum.com/forums...-pump-diy.html
Old Jun 18, 2017 | 12:55 PM
60 SHARK's Avatar
60 SHARK
Thanks for posting it,,,,
Old Jun 18, 2017 | 02:01 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
What 60 Shark posted will not work with a '74 gas tank; 68-74 tanks are different than the later models.
You have a few choices with a stock '74 tank:
New FI tank from Tanks Inc:
http://www.tanksinc.com/index.cfm/pa...rod/prd443.htm
Tanks Inc retro-fit fuel pump module:
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
Aeromotive Phantom Stealth retro-fit module:
https://www.aeromotiveinc.com/produc...h-fuel-system/
Vetteworks retro-fit kit:
http://www.vetteworksonline.net/ls1_conversion_fuel.htm
Rock Valley retro fit module:
http://www.rockvalleyantiqueautoparts.com/catalog.htm
Rock Valley has it listed under "Tune Port Information and Kits" on their website; but you are better off calling them with your exact needs.
I went with the stainless Rock Valley retro-fit fuel pump module on my '72 when I converted to EFI with the FAST Ez-Efi system. This is a pic of my finished tank:
Some more pics of my tank build are in this thread, starting at post #5:
https://www.corvetteforum.com/forums...fuel-tank.html
To EFI swap/ Fuel sender option.
