Already running but starter keeps going
Old 08-22-2009, 07:42 AM
Twisted99
Twisted99's Avatar
Default Already running but starter keeps going
Went to leave work Thursday, turned the key and started as usual except for this loud squeal like a locked AC clutch, I turn the ignition off and the starter keeps engaging. I quickly disconnect the negative battery cable, when I tried to reconnect same thing: starter turns. I disconnect the positive side and wait 2 minutes, reconnect and starts up normal. Where do I start?
Old 08-22-2009, 09:13 AM
crainholio
crainholio's Avatar
Remove starter and take to parts store for testing.
Old 08-22-2009, 11:42 AM
lucky131969
lucky131969's Avatar
With the battery disconnected, I would inspect the starter wiring. If it looks good, I would disconnect the solenoid wiring...then reconnect the battery, and check for 12 volts at the S terminal (purple wire) when the ignition is turned to the start position. You want to make sure the voltage drops out when the key is turned off. If that is good, then the solenoid is probably shot.
Old 08-22-2009, 12:30 PM
Blown427conv
Blown427conv's Avatar
IMO the solenoid is probably shot. I've experienced this before with a bad solenoid.
Old 08-22-2009, 08:58 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Lucky and Blown427conv have excellent recommendations. If you have constant voltage on the S (purple wire) the theft deterrent relay (TDR) is stuck in the ennergized state. If the purple wire has zero volts, the solenoid is stuck in the ennergized state.
The TDR located in the passengers foot well above the Body Control Module (BCM).
The four wire colors are Purple, Red, yellow/black stripe and yellow
Old 08-22-2009, 09:17 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Old 08-23-2009, 09:20 AM
Twisted99
Twisted99's Avatar
This has only occurred once. If I check the voltages now won't they be "normal"?
Old 08-23-2009, 11:38 AM
lucky131969
Obviously they will if you can duplicate the problem. I guess the action you take depends on if you want this to happen again....and it will happen again. At the very least, I would inspect the wiring at the starter, and replace the solenoid...
Old 08-23-2009, 11:40 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
yes.
i had this happen once when i had just put a new motor in a lincoln LS and a wire on the starter was hitting something on the solenoid and making it stick.
actually i had something similar happen a supercharged camaro i built a while back.. except i destroyed the flywheel and starter when it happened on that one,
Old 08-23-2009, 01:12 PM
Blown427conv
I'd think about replacing both the solenoid and TDR relady ASAP. If you frag the flywheel, the pain really begins, not to mention possible overheated wires and overheated battery if you can't get it shut down in time.
Old 08-23-2009, 01:40 PM
Twisted99
Twisted99's Avatar
I will check the wiring, and probably replace the solenoid ASAP. I have not looked yet, does the starter need to be removed to replace the solenoid?
Old 08-24-2009, 02:19 PM
Blown427conv
The starter has to be dropped to get the solenoid off or there will be very little access to it. Disconnect the negative battery cable before you do it. I think the front of the exhaust has to be dropped to get it off also. (starter)
Old 08-24-2009, 03:04 PM
dankhts
dankhts's Avatar
weak solenoid spring.....supposed to return the starter drive gear back to the dis-engaged position... if it only happened once, it will probably happen again sooner or later...most likely sooner...
Old 08-24-2009, 09:36 PM
jedblanks
jedblanks's Avatar
If you can easily loosen without removing the starter (after disconnecting battery) then you can try some white lithuim grease on the bendix. In the past this has allowed me to keep a starter working longer. However if it's a lot of labor (exhaust etc) to loosen, then you might as well replace.
Old 08-26-2009, 08:19 PM
Twisted99
Twisted99's Avatar
Thanks everyone I will check the connections this weekend, and if they are good looks like I'll be pulling the starter and replacing the solenoid
Again, THANKS for all the info.
Old 08-30-2009, 03:23 PM
Twisted99
Twisted99's Avatar
OK, so I checked the connections and the look OK, but there is a loom that looks like in is being pinched. I took some pics that I will post later.
ALSO, I had the "service column lock" crap back in December and took it to the dealer (no recall done prior) today I'm getting "pull key and wait 10 seconds" and "service column lock". Car dies if I try to move more than a few feet. The battery was NOT at full charge when I got these messages today. So my question is could ALL this be ignition switch related?
Old 08-31-2009, 12:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Battery MUST be fully charged. Yes the Ignition switch can cause this issue. It will limit the voltage to the BCM as well as other modules. Best bet is to do some checking with a volt meter.
BC
To Already running but starter keeps going
Old 09-07-2009, 10:44 AM
Twisted99
Twisted99's Avatar
BC
Had the battery tender on all week, started up today, and got 'pull key and wait 10 sec". Where do I start checking with volt meter, or could this be related to the recall i had done in December?
Old 09-07-2009, 10:51 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check out this post:
http://forums.corvetteforum.com/c5-t...ch-repair.html
Old 09-07-2009, 03:37 PM
Twisted99
Twisted99's Avatar
Checked all the fuses mentioned in the other thread, and all have battery voltage, 11.5-12.8v. If I hook up a battery charger and check they all go up to 14v range. As soon as I turn key to the ON position, not Start, I get "service column lock" or "pull key and wait 10 sec." Should I be reading the column lock thread...AGAIN
Quick Reply: Already running but starter keeps going
