2 piece rotors for C3's
Does anyone know of a company who makes the 2 piece rotors/front and rear for a C3. I can only find them listed for 1997 and up......
Thanks Markus, I was wondering what the weight savings is per rotor, maybe 2-3 lbs. with the aluminum center. I see you have Wildwood calipers, I'll see if they make the standard size rotors to use with the OEM calipers......
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
You might check Wilwood's website or one of their catalogs. I put two-piece rotors (and Wilwood calipers) on my '69 last year. Note the difference in rotor weight (5# less) and caliper weight (7# less), resulting in a weight reduction of 12# per corner (14 vs 26).
I have a C4 suspension on my '69, so I had to do some mixing and matching of the rotor and hat sizes so I could retain my 15" wheels for street driving, but still have capable brakes during track days.
Premium Supporting Vendor
Wilwood is going to be the lightest if thats what your after for the front. The rear's are maybe a pound lighter b/c a steel hat has to be used vs an aluminum hat b/c of the parking brakes.
Front 13" rotor w/hat are 14.5#'s each.
Rear 13" rotor w/hat is 19#'s each.
Front Kit
http://www.vansteel.com/index.cfm?fu...p=1961&ID=3011
Rear Kit
http://www.vansteel.com/index.cfm?fu...p=1961&ID=3003
Wilwood info and specs
http://www.wilwood.com/BrakeKits/Bra...model=Corvette
Front Kit
Rear Kit
I hope Keith at corvettengineering.com reads this
The 8 bolt hat and 13 inch rotor sets that I got from him in the kit are less expensive. But I since changed to the real deal at the below link.
These 12 bolt "GT" type are far superior for only a small cost increase
http://www.wilwood.com/Rotors/RotorList1.aspx
[QUOTE=gkull;1575026792]I hope Keith at corvettengineering.com reads this
http://www.wilwood.com/Rotors/RotorList1.aspx[
Thanks all for the info, wow what choices to make, my intensions are to just replace the heavy rotors with some lighter ones, I have the drilled and slotted rotors from Rotor Pros which have been working fine but are close to OEM weight. Just trying to loose some rotating weight and improve with some better pads/Hawk HPS for the yearly xcross event we do here...I sent Keith a pm and are waiting to see what he recommends....
C6 the C5 of tomorrow
Jay,
I got your PM, thought I'd answer here.
Corvette Engineering is basically done, it's hard to compete with the likes of Vette brakes and the mother ship, Wilwood...
I still have a bunch of brackets and a few calipers sets, but I'm not working at selling anything any more. I had my fun :-)
OK, 2 piece rotors, you get a slight weight reduction, but most of that is unsprung as it's all in the hat area, but hey, thats good too! 2 piece really excel when you are getting on them. they cool a lot better. Around town, meh, whatever...
There is always that bling factor too, just like slotted / drilled rotors ( sorry ). If you are slotting or drilling your rotors, you would be better off going to a smaller rotor, diameter, or width.
There is nothing magical aboutmy 2 piece rotors, I just did the background work.
The hats are Wilwoods 171-2234, they are undrilled so you have to have the stud holes drilled and the center hole drilled out. But the offset is really close. Sometimes a .020" shim is needed.
The rear hats do have a different offset...
The rotors are all over the place (Behlings). You can get really nice heavy duty curved vane rotors, or ultra light straight vane rotors. Pick your poison.
But basically use the lightest cheapest rotor you can get away with. Big rotors are like big ****, mostly for the looks, the babies don't care and neither does the car.
Does this help?
Does this help?
It's only a lapping car that would over power smaller or stock brake setups. As tire size and power goes up is where you need big rotors.
Thank you for giving it a go. I wouldn't have decent brakes on my car and wouldn't have been able to do track days without your efforts. The stock calipers just don't cut it for a 20 minute lapping session. I don't give a crap what anybody says.
I have your original aluminum dynalite brackets with billet dynalites. I expected the brackets to fatigue crack after a few years but they haven't yet. And they fit perfect. You're a good engineer my man.
I don't think i've ever given anyone here a compliment like that before. Mostly i give people crap.
Jay,
Does this help?
Does this help?
Just to clarify, I'm not quitting or closing shop, just not trying hard anymore. ( I haven't for a while actually)
What that means is I won't be carrying as much stock, and I won't be pounding the pavement trying to sell. If someone want to work with me, cool, just don't expect Summit racing speed and selection
I am still here for advice, discussion and the fun of it. Corvette Engineering never was a 'Business' more like a hobby. I have turned away a few people and told them to run stock brakes.
I still think my kits are a great deal, and I'll sell any part of the kits, like just the brackets, I have a butload of 13" brackets I'll sell cheap...and tell you what part numbers are known to work.
I suppose I should publish the specs so people can do it them selves.
Neither is better than the other, just different applications.
Yea, those brackets were a bitch, double sided CNC machined, $$$ but they were designed to handle 20 times the max force you could generate if you could stop the car at 1G with just 1 wheel...
If you ever want the new style brackets, I'll give you a set. You'd need new calipers tho.
Sorry to bump an old thread here but I'd really like to take advantage of this type of setup for a 1965. 2 piece 11.75" rotors would be great. Would anybody be able to tell what of the model numbers above/ information in this thread applies to a c2?
Go to Vansteels website and look at Wilwood brake kits for c2
My rotors are 11.75"/1.25" size Wilwoods. Wilwood also has a lot of different offset hats for their rotors. Respectfully, where are you running into problems with a two piece setup?
