oil leak
oil leak
Ok ladies and gents, I have a Moroso pan on this engine and the only way I could get everything to not leak is going with the original cork gaskets and just snugging the bolts incrementally. The engine is bone dry except for a leak out of the front oil pan seal, kind of like it could be tightened to seal it but if you do, it will smash the cork on the sides and it would leak there as well, does anyone have any tricks to seal this, add washers to the front bolts or something like that? Just curious as I don't want to have to take the oil pan off again just for this. By the way the felpro one piece never worked for me and I pitched it in the trash!
Put a dab of Permatex black RTV sealant at each joint between the pan gasket and and end seal. Your problem may also be that you applied too much torque to the pan rails and have distorted them. Tightening more will just make it leak worse, if that is the case.
Better gasket to use is Fel-Pro composition gasket (cork and synthetic rubber mixture). Pan rail needs to be flat; engine rail and pan rail need to be absolutely free of contaminants AND OIL (use volatile cleaner before installing). Install bolts and torque to 1/3 or final torque value; then go around again to 2/3 of final torque; then again to final torque. It won't leak.
EarlyC34me (04-30-2017)
Nam Labrat
Received 4,178 Likes
I had similar problems with cork and 1-piece gaskets even after resealing the pan 3 times/using gasket sealer on the cork also.
I ended up removing the pan and laying it upside down on our granite countertop (when wifey wasn't home). The pan showed several "twists and dips" just bad enough to cause the gaskets to pinch in some areas while not sealing enough in other areas.
I used a plastic-tipped hammer/mallet to straighten the sealing edge of the oil pan so that it laid evenly on the granite with only minor gaps (less than 1/32").
No more leaks! I hope that helped you look for a warpage problem.
Is the pan chromed? If the seal surface is really slick (as in plated or chromed) the gasket won't have anything to "bite" into and can crawl around.
