ground strap at engine
Old 05-28-2017, 01:43 PM
71 f/w driver
71 f/w driver's Avatar
Default ground strap at engine
I noticed that the engine ground strap on my 71, 350/270 is 18 1/2 inches long and is #2 gauge. What is the correct strap length and gauge?? I plan on making a new one from this old one if 18 1/2 inches is to long..
Thanks
Mike
Old 05-28-2017, 02:10 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Mike,
The original engine ground step on my 71 350/270 is 12-1/2" long from the center of the connector at the block to the center of the connector at the frame engine mount arm.
Regards,
Alan
The following 2 users liked this post by Alan 71:
MISTERZ06 (05-29-2017), Primoz (05-28-2017)
Old 05-29-2017, 10:40 AM
71 f/w driver
Thanks Alan for the quick reply. I'll save few $$ by shortening existing.
Mike
Old 05-29-2017, 12:59 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Even though it wasn't done that way at the factory, I would highly recommend that you not only crimp the end terminals on the wire, but that you solder them WELL, also. This will assure many years of a solid ground connection between the battery and the engine/starter. One of the downsides of only crimping those connections is that water will wick into the crimped wire joints and eventually degrade the integrity of the electrical connection.
Old 05-29-2017, 04:02 PM
kanvasman
kanvasman's Avatar
Shrink wrap over the end, just leaving the eye uncovered, will also help keep out the corrosion.
MISTERZ06 (05-30-2017)
Old 05-30-2017, 11:10 AM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
if you don't have a monster soldering gun,
bubba says... you can use an electric stove element to heat the crimps,
and solder them onto the wire.
EarlyC34me (05-30-2017)
Old 05-30-2017, 12:57 PM
CA-Legal-Vette
CA-Legal-Vette's Avatar
Thank you Bubba, that's pretty clever.
Old 05-30-2017, 07:36 PM
7T1vette
7T1vette's Avatar
Uhh....I think that's what propane torches are for. A little flux; a little heat; and a string of solder will fully adhere each lug.
To ground strap at engine
Quick Reply: ground strap at engine
