[C2] 1966 Door Panel Vapor Barrier installation
I'm in the process of rebuilding my door locks, etc., and I'm replacing the 50 year old vapor barrier. I'm trying to figure out what product to use to replace the original white (caulking?) that was used by the factory to attach the door panel vapor barrier. Anyone know what will work best?
Received 6,943 Likes
2015 C2 of Year Finalist
Dum Dum is what its called in the body shop. go to your local hardware store and get some window strip caulk in white
OR....If you are not worried about being factory correct...you can use 3M's black strip caulk and that will due just fine.
DUB
DUB
string or "rope" caulk. In the insulation section of your home store. Or at RV supply store. It's the right color and much easier to work with. 3M strip caulk is overkill for this application.
