1970 Fuel Tank Size?
Just another Corvette guy
Y'know, I've probably had 20 or 30 copies of the Corvette Black Book over the years and never noticed this bit of info before. In the 1953-2007 Edition, at the rear of the book where they show pictures and list the specs for each year, they list the 1970 as having a 20 gallon fuel tank, (just like all other Corvettes back to 1963), except California which had a 17 gallon fuel tank for 1970. No other years show this difference. Now I'm curious why and if anyone else has noticed this or can confirm it? I can't think of any emission related equipment that would account for the one year difference.
Received 2,878 Likes
Hi Greg,
Did the difference in capacity have something to do with the ECS (Evaporative Control System) that 70 cars being delivered in California had and ALL cars had beginning in 1971?
I believe it was the same tank but the ECS sealed tank couldn't be filled as far as the vented tanks could.
The capacity for gas tanks was given as 18 gallons in 1971, they all had ECS and were sealed systems.
Regards,
Alan
Regards,
Alan
Alan, you could be on to something there. I can't think of any other reason.
Greg
Greg
70-72 Corvettes all use the same 18 gallon fuel tank. The 1970 49 state cars did not have the evap canister, but they do have the vent valve, which just vented to the atmosphere. Why the black book lists anything else I have no clue.
Given my ancient and infirm state of mind, I may well be misremembering, or maybe remembering alternate facts... I seem to recollect that the 'filler' was extended down into the tank, which would, effectively reduce its capacity, tho the tank would remain the same size.
Hi axe,
What are you referring to as the 'vent valve'?
Regards,
Alan
Regards,
Alan
Location: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
While that is true it is probably not realistic to think that people could pump gas into a small filler neck once the level reaches it and expect the tank level to equalize before the filler neck over-flowed.
Hi axe,
I asked because I thought perhaps you referring to the 'button' relief valve which both non-EEC and EEC tanks have.
70 non-EEC tanks do not have the nipples or brackets for the vapor separator.
Regards,
Alan
Regards,
Alan
Was looking at tanks as mine is rusty on the outside, but clean as a whistle on the inside. I have not yet found one without the vent pipe. Perhaps one made for an earlier year would work?
