Speedometer Died. Options?
My speedometer on my 69 was consistently reading about 10 mph. too high. (I have a gps speedometer app on my cell phone) Yesterday as I was driving about 60 mph I looked down and it suddenly was reading about 100 mph and then it went to zero where it has been since then.
I am assuming this is the speedometer itself and not the cable or trans but will check later
If it is the speedometer, what are my options? Is there a "go to" place for repair of my unit? Or is it cheaper to replace with a new or used one?
Does anyone make a gps one that looks like the factory one?
Thanks
Glenn in San Diego
Thanks
Glenn in San Diego
Emerging Vendor
Seems strange to me, the cable usually binds causing a bouncing speedo needle. There is a plastic gear in the transmission that the speedo cable goes into. The problem may be there.
One of the other members here lost his speedo on a long road trip. The square for the cable in the driven gear in the trans decided it wanted to be round.
Received 2,878 Likes
Hi Glenn,
After checking the gear and cable as Greg and Tim suggested…..
If you decide you need to have the speedometer itself repaired you might consider bringing/sending it to Corvette Specialties of MD West. They're in Palm Desert.
They used to be located on the East Coast… that's why I'm familiar with the work they do.
Regards.
Alan
Regards.
Alan
Primoz (09-22-2017)
Primo
Most likely the cable as well, mine would bounce around after 40mph and would dive about 20-30 mph. If I went slow and steady no issues. I decided to change the speedo cable and it solved my issue. When I was playing with the old cable the 40 year old grease was like clay. This was about 8 years ago and still working good.
Primoz (09-24-2017)
2017 C3 of Year Finalist
Primo
I'm a small guy with thin noodle arms and I was able to unscrew it out and swap it. It would help if the drivers seat was out. So I did it without dismantling the dash. But it is very tight. Have a beer before you start to relax.
I pulled the speedo cable at the trans, put a drill motor on it, and it didn't budge the speedo needle. I then pulled the cable at the speedometer and ran the drill motor again. The cable was spinning at the speedometer end. However, what should the end of the cable look like
at the that end. I looks a bit wimpy to me. Is this what it should look like? Here is a pic
I would say it is sheared off and you will find the rest of cable end in the speedo. Your missing a half inch or so of the square cable end that drives it.
gleninsandiego (09-25-2017)
Received 2,127 Likes
That looks like some kind of aftermarket repair tip.
