61 Z Bar looks odd
Old 02-19-2018, 03:53 PM
jerry gollnick
jerry gollnick's Avatar
Default 61 Z Bar looks odd
Doing some work on the 61 frame off today. I installed the clutch linkage and the angle between the rod going to the pressure plate and the clutch pedal arm looks incorrect. I expect the arm going to the clutch arm to be pointing down at the ground rather than than forward. Just for reference I adjusted the rod to have the clutch arm so that the throwout bearing is just starting to touch the pressure plate. I know these arms press on with serrations is it possible one is installed incorrectly?
Old 02-19-2018, 04:02 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Looks odd to me. That arm should be in the down position....Check out how the diagram looks.....
Old 02-19-2018, 04:04 PM
jerry gollnick
I agree. Any specs on angle between two arms on Z bar?
Old 02-19-2018, 04:13 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
silly question, but does it work that way?
but, if you look at the angle between the 2 arms they appear to reflect the AIM; the outside arm is rotated too far back and the pushrod to the throwout fork is way too long to let the inner arm rotate back to where it should be.
Bill
Old 02-19-2018, 04:16 PM
vettsplit 63
vettsplit 63's Avatar
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
Are you sure you have the right clutch rod? It looks awfully long to me.
Old 02-19-2018, 04:36 PM
jerry gollnick
Bill
I adjusted the length and shortened the rod but it still seems wrong and the amount of tension on the gorilla spring is pretty significant.
The aim suggests to me the arms are approx 160 degrees apart from center to center. Mine are at 90 degrees. I really need to know what the separation angle is supposed to be.
Old 02-19-2018, 04:38 PM
jerry gollnick
It's what paragon sent me. Lot's of adjustment still available to shorten rod. I can measure if someone knows what lengths its supposed to be.
Old 02-19-2018, 04:44 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
90* is close but its prob a bit more -- like 100*-120*...here is a new 1961 that the British did an analysis of in their famous MIRA document...look at the angles...
Old 02-19-2018, 04:46 PM
jerry gollnick
Even in this photo the inner arm is not pointed down (90 Degree) to ground as shown in the aim. maybe image in aim is not correct. In this image Gorilla spring is not attached so It's hard to tell if this is an "as adjusted" position or one that would change if gorilla spring were attached. On my Z bar the two arms appear to be 90 degrees separation. In this image and aim images it appears, just eyeballing, that they should be more like 160 degrees separation.
Old 02-19-2018, 04:53 PM
vettsplit 63
St. Jude Donor '12
Mine is as Frankie described above, probably 100-110 degrees . Your rod is about three inches too long.
jerry gollnick (02-19-2018)
Old 02-19-2018, 04:55 PM
jerry gollnick
I will adjust rod length and reposition inner arm to 110 degrees separation and take another photo. should the Gorilla spring be under tension at rest?
Old 02-19-2018, 05:05 PM
Frankie the Fink
Army
Yes. The Gorilla spring will have some tension at rest -- otherwise it would let the hairpin clip on the frame bracket fall right out of its slot...
Old 02-19-2018, 05:32 PM
jerry gollnick
OK I adjusted the clutch rod lenght to appear as in the English photo. I'm going to have to stretch the gorilla spring at least an inch to get it to go on in this position. lots of tension. I'm confused as to the function of the gorilla spring. is it a return spring or assist spring. From the geometry it appears more of an assist. which would suggest the center of the attaching arm to the gorilla spring should be roughly in line. Is there a trick to install the Gorilla spring?
by the way the total light of the clutch rod is 9 1/2 inches. don't know if thats correct.
Old 02-19-2018, 05:43 PM
jimh_1962
jimh_1962's Avatar
2018 C1 of Year Finalist
makes it a lighter pedal for the brake over. Really you do not need to use it if you installed a diaphragm style pressure plate.
Also, ditch the repro rubber grommet on the repro shoulder bolt. Its too sloppy and really not ideal. You will eat them up with in a few presses on the clutch. Better off going with a brass bushing or poly bushing.
Use the method Frankie describes using a crescent wrench
Old 02-19-2018, 05:45 PM
Frankie the Fink
Army
The gorilla spring is a "bistable" device. Its purpose is to smooth out the 'force over distance' curve as the user engages/disengages the clutch. It actually creates a more uniform, even operation of the clutch in both directions. It is NOT a return spring.
Think of bistable as it applies to old fashioned house light switches. The switch is pushed from a certain position in either direction when it then 'flips' to the opposite stable position with minimal force.
That's all it is ..
Old 02-19-2018, 05:46 PM
jimh_1962
jimh_1962's Avatar
https://www.corvetteforum.com/forums...king-help.html
https://www.corvetteforum.com/forums...g-install.html
I guess in one word it makes it more feeling the break over point compared to just installing a lighter spring.
https://www.corvetteforum.com/forums...la-spring.html
wmf62
wmf62's Avatar
St. Jude Donor '07
It is an assist spring and will slightly overcenter. Some folks eliminate the gorilla spring as just use a pullback for a pedal return.
I don't remember exactly how it is adjusted, but I know there are numerous threads on how to do it
Bill
To 61 Z Bar looks odd
Old 02-19-2018, 05:47 PM
Frankie the Fink
Army
As described in the ST-12 manual a crescent wrench placed as shown in red that is used to 'rock' the Z-bar forward will find the 'sweet spot' where the spring almost jumps into place. The ST-12 also has the adjustment procedure but there really isn't that much "adjustability"...
People that remove the spring must not have done well in geometry class...its not a difficult concept..
Old 02-19-2018, 06:13 PM
jerry gollnick
Yep. i played with the adjustment and can find a neutral point and a point where it pulls back or slightly pulls down. interesting geometry. there is also an adjustment on the arm that the spring attaches to. It acts like a fine tuning adjustment. However, all that being said there is no return spring. only a small anti rattle spring. With no return spring how is returned accomplished? When the gorilla spring is adjusted to neutral it is not stable. So my guess is it's adjusted to be slightly pulling back and acting as a return. ST12 is not very helpful here. The second photo shows the spring in a neutral position.
Old 02-19-2018, 06:15 PM
jerry gollnick
Do you have a supplier or part number for a brass busing?
Quick Reply: 61 Z Bar looks odd
