Question about clear coating
I'm interested in purchasing a car. I've been speaking with the owner, who lives in a different state, so I can't see the car in person but he has sent me pictures and videos. He told me that the entire car is "clear coated" front to back and then showed me a video of a few places where they couldn't "wrap" the clear coat all the way around the car (for example there is a visible line above the side mirror where they couldn't finish the clear coat all the way.)
I know cars are clear coated from the factory, but I didn't realize there is an option to clear coat in the aftermarket. What exactly does it mean to clear coat the entire car? Isn't that just the same as what they do when it's built from the factory?
Also does anyone have any pictures of their cars with clear coats? Do you also have edges or areas of the car that couldn't have a clear coat on them? To me the lines he pointed out on the car where they couldn't clear coat look ugly because they are very visible (to an OCD person like myself). Just wondering what everyone's thoughts are.
Something sounds fishy. These cars come from the factory with a clear coat. There is no extra clear coat option. Why would he do that and have lines around the car. I would run away as there are plenty of nice C6’s around. Good luck
He must mean clear protective coating such as 3M. I've never seen an entire car done with it but I suppose it's possible. There will be a slight visible edge where it ends. I think it mostly shows up on lighter colors like white or yellow.
Clearcoat is paint. It sounds like there is confusion between the difference between clear coat and a protective clear wrap. There is no factory option for extra clear coat or protective films. I've heard of people installing a protective film on the entire car. It usually is just for the front end of the car as to do the whole vehicle gets expensive. I had a 3M protective wrap on my car but recently had to remove it as a red fungus started growing under the surface of the protective film. You can peel it off, use wax and grease remover to get the sticky adhesive off the surface and wax the paint surface afterwards.
I am not, sure I would like the whole car done in this way, it will eventually have to be removed, the film does not last forever
It sure sounds like he is referring to paint protection film. You might want to see if a member here who lives in the seller's area can take a look at the car for you. That's what I would do.
Received 1,681 Likes
Doesn't sound like he knows what he's talking about.
I was confused as well, as I have never heard of "clear coating" a car (except for when the car is being painted with factory paint). I asked him about it and he continued to call it a "clear coat" but then said it might be the same as a clear bra. So yes, I think he is now referring to a clear bra and there was just some confusion there.
So with that being said...what are your thoughts on clear bras? I understand their purpose but to me, I've never really liked them. I know they don't last forever, and can fade in certain areas, and you can usually see lines or edges where they couldn't wrap it completely. He showed me in the video two lines above both side mirrors where they couldn't wrap it all the way.
I'd almost rather take my chances at getting rock chips and dealing with them myself rather than having a clear bra. I don't know, I've just always disliked clear bras mainly because I'm OCD. It also concerns me a bit that the clear bra is on the entire car front to back side to side top to bottom. If something goes wrong with the bra and it has to be removed, I don't think there would be a problem removing just a front clear bra like most people have but removing a bra around an entire car seems like it could be a hassle.
The current owner is using the wrong terminology which is misleading. As others have indicated, "Clear Coat" is the factory base coat/clear coat process for painting the car. What he may be referring to is a vehicle clear wrap which costs $3 to $5K or a ceramic paint coating which is a product similar a wax or sealer only much more permanent . You need to clarify exactly what he is calling "Clear Coat".
Are you able to post pictures here on the forum. If we could see it we may be able to diagnose it better. From what it sounds like, He's referring to some type of paint protection film. Not many do the whole car as it'll run you around 3k but it's not unheard of.
My first C6 was a new JSB coupe. I had 3M protective film put on it. I covered the nose and 1/3 up the hood, mirrors and behind each wheel. If you have a good installer it is great and barely noticeable. There is no way I’d cover the entire car.
This can be removed with no issues.
Ask the owner where he had the car coated and then talk with the installer.
https://ghostshieldfilm.com/
I would never buy a car from private owner that didn't know the difference between clear coat and clear protective film. I would assume he didn't know what he is talking about. What else, doesn't he know about that Vette?
Depending on what kind was used, clear wraps can yellow with time. They can also turn brittle after some years, especially if the car bakes in the sun in a hot climate, and actually bond to the paint-clearcoat so removing it can cause damage. I had this happen with the stone guards on my 911. I have been informed by several high-end paint/body guys that ceramic coatings are an added complication when paint repairs are needed. Personally I'm not doing either to my cars, and it would be a negative selling point if I were shopping.
I think you can buy a partial vinyl clear coat for our Corvettes ??....like just the front part of the hood...etc. But can you buy it for other vehicles like pick-em-up-trucks...etc.? Or would you have to buy a big sheet and then cut to fit ??
Sounds like he's talking about clear protective wrap. Done right, you can't tell it's even on the car without a really up close inspection. Some protective wraps are self-healing, so I'm told. But, check into it if there are flaws. It can be peeled off if it's not in good shape.
