[C1] Installing side window glass in 1957
From everything I have found on assembling the door glass and reveal mouldings with felts, the outer felts and outer reveal moulding have to be screwed into the outer retainer as a unit and they get fastened to the door posts and installed together . If that is the case how do you slide the glass down into the door with the door post already installed . The door post area is the only slot big enough to install the glass vertically ? Is there a trick to installing the glass with everything else installed ? Is there enough room with the inside trims left off to spread the inner fiberglass panel enough to slide the glass in ?
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
The outer molding have studs that go in from the top. Only the inner molding attaches with screws. The felts attach with staples or you can use rivets if its too difficult if you don’t care about originality. It’s been a long time since I pulled one out but at least the inner will have to be off to get the window back in. It’s a pain to get the outer off or on with the window installed. Good luck.
bj1k (05-08-2018)
Im glad to hear it helped.
1957 door posts with window removal
I appreciate this thread, very helpful. I'm in process of changing out my window and hardware for it on my 1957. Do the door posts have to be removed when the window is removed? Or can the window be removed without them?
Via (01-01-2019)
Via (01-01-2019)
Window Removal.
Thanks for responding but there are no studs on the outside mouldings . The only stud that goes down through the fiberglass is on the rear of the door post and at the rear is the clip that holds the horseshoe trim on with one screw. All of the drawings in the vendors catalogs show screws going through the outside retainers from the inside to hold the outer felt and outer reveal molding on .
For the life of me I cannot figure how to remove the door glass.
Thanks for any info,
Jonathan.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
You are responding to a post from 2018.
