Should there be a nut on the front spring?
Old 07-16-2018, 09:21 PM
billschroeder5842
Zen Vet Master Level VII
Support Corvetteforum!
billschroeder5842's Avatar
Received 1,143 Likes on 846 Posts
Default Should there be a nut on the front spring?
While doing a front brake bleed I noticed that the front springs had a threaded bolt (ride height adjustment?) popping through a drilled hold at the end of the springs. There was no nut on the top of the of the bolt holding down the spring. There is obviously a lot of tension so the risk of coming off, but should their not be a bolt or at least a safety clip of some sorts?
Old 07-16-2018, 10:06 PM
Arvalo
Arvalo's Avatar
Lol, I did my brakes over the weekend and noticed the same thing. I’ll be curious to hear this answer.
Old 07-16-2018, 10:22 PM
billschroeder5842
Well if there are two of us, it is either a GM design or we got the same guy on the line.
Old 07-16-2018, 10:37 PM
ArtClassShank
ArtClassShank's Avatar
There isn't supposed to be anything there. The spring bows upward as you drive down the road. That bolt you see is indeed the ride height adjustment. I believe its primary function is to center the pressure of the spring into the lower control arm. The spring is threaded, and since the bolt is under tension, it's not going anywhere.
Old 07-17-2018, 07:28 AM
ArtClassShank
Originally Posted by 8VETTE7
What do you base that statement on???
Here is a thread on lowering the C5 that shows a thin metal retainer on the front bolts. Many cars including my 04 came from the factory with the metal retainer:
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
Scroll down to the section called "Lowering the Front" and click on the first and second pictures in that section........
I stand corrected! I'm a 2nd owner so I guess mine were removed.
To Should there be a nut on the front spring?
Quick Reply: Should there be a nut on the front spring?
