Explain the PDR Circle G-Meter Values Please...
Any of you race guys who have aftermarket G meters, to compare to the footage later.... can you explain the PDR Circle G-Meter Values Please...
What is the inner ring's value? What is the outer perimeter ring's value?
Below photo is on pilot super sport tires... How many G are being pulled?
Received 8,929 Likes
What is the inner white ring's value? What is the outer perimeter ring's value?
You get a lot of data from the PDR but you have to use the Toolbox to see it. You can also use Pi Toolbox to look at other data collected.
Here is some more from the same lap:
Video going into Turn:
Data taken where the video stopped:
Bill
so you dont have an estimate what my G rating is when im just inside the first ring?
Bill
The following 2 users liked this post by Bill Dearborn:
Mikec7z (07-17-2018),
Trackhawkz06 (07-17-2018)
No. No way to do that. I don't even know if there is a statement of what that first ring means. Just like when you hit the 1.25 G indicator you really don't know your G number because it can be a lot more than that. Even in Toolbox you don't know the G force at a particular position in a corner it just gives you max Gs although I suspect it is available just ignored in the software. Pi Tool Set lets you graph G force so you can see how it plots through a corner.
Bill
Bill
