Rear End and Manual Trans Fluid change
Old 08-15-2018, 12:23 AM
Marc DeSatnik
Marc DeSatnik's Avatar
Default Rear End and Manual Trans Fluid change
Anyone have instructions for changing manual trans and rear end fluids in a c7?
What fluids do you use and how much do I need?
Old 08-15-2018, 08:59 AM
Bohacker
Bohacker's Avatar
Both have fill and drain plugs so you will need a pump to fill. Tranny takes 4 qts, diff takes 3. I use Redline D4 ATF in the tranny (M7) and Redline 72W-90 GL-5 in the diff. Plenty of threads on this topic so search for more in depth discussions.
Marc DeSatnik (08-15-2018)
Old 08-15-2018, 09:00 AM
Kracka
Kracka's Avatar
Received 5,716 Likes on 2,921 Posts
Here's the DIY thread I put together a few years ago: https://www.corvetteforum.com/forums...d-service.html
To Rear End and Manual Trans Fluid change
Quick Reply: Rear End and Manual Trans Fluid change
