New bulbs
New bulbs
recently replaced my OEM bulbs with Wagner BL 9006BLX2 brigh lights. Better than OEM but still not good. Did same with Hi’s 9005. Told 80% brighter. Any of you have used them or remarks about them. Wanted 9011 and 9012 but mechanic will not install due to mod of tabs. Know of anyone in the Punta Gorda or port charlotte fl area who would do the job. !!!!!! Thanks much. Fin . right now running hi’s at night
The issue is with the housing, not the bulb. The OEM housing does not direct light very well, you're only going to see marginal improvements after putting in brighter bulbs. Get a set of projector headlights (Radioflyer makes a good set) to see real improvements.
Having said that, the 9011/9012 modification takes about 30 seconds with simple tools, instruction videos are all over Youtube.
The projectors are the cat's ***. I have a set of Radio Flyer's stealth cannons on my C5 and they're worth every penny - WAY better than stock. I just wish he'd had the low profile popup style when I was in the market - I like the looks better than the fixed style.
Until you get some projector headlights, you might think about some LED bulbs. I put some on my son's toyota, which uses the same 9004/9005 headlight bulbs as the C5, and the improvement was like night and day.
There are LED bulbs that fit directly into the C5 without any further modifications, but you'll find that LED bulbs can be rather high priced. You'll pay in the area of $70-$100 typically to change just the low beams to LED.
The 9011/9012 HIR conversion mentioned following your initial post is a good under-the-radar modification that is a solid cost alternative. While not as high output as LEDs, HIRs will light better than OEM and they're very similar to 9004/9005s sans a slightly larger mount tab that has to be trimmed. HIRs some years back used to be fairly cost prohibitive but they are so common now that they have come down in price. They're comparable in price to say Silverstar halogens.
https://www.corvetteforum.com/forums...-low-beam.html
https://www.corvetteforum.com/forums...nd-9012-a.html
https://www.corvetteforum.com/forums...4-harness.html
I also used my favorite video search engine and found a tutorial, feel free to watch through. Again, the process is very simple.
The best cost/performance ratio is to modify the HIR 9011 bulbs into the stock Halogen housing. The alternative is to buy a set of real projector headlights and a set of LED bulbs or HIDs if you wanted a significant upgrade.
They are plug and play after cutting the tab. I used my favorite search engine and found a couple of posts regarding this (there are hundreds), feel free to browse through for more information.
https://www.youtube.com/watch?v=iviAlp6x3m0
LED bulbs can be found for about $20-$30. Unfortunately, LED bulbs in Halogen housing have the same detrimental effects has HIDs in Halogen housing: they blind oncoming drivers. So I would highly advise against LED bulbs in stock housing.
As far as blinding oncoming traffic, the LED's are way better than the HID's in stock headlight capsules, in my experience. The LED's are designed to fit the stock housings, so they scatter much less light into the eyes of oncoming traffic. I've never been flashed while driving my son's toyota, even on long straightaways when the oncoming driver had plenty of time to let me know the lights were bothering them. Some of the LED bulbs even .
CorvetteBrent (09-21-2018)
They're plug and play. And the wattage is the same or slightly lower than halogens, so no worries. You can find them pretty cheap on Amazon.
As far as blinding oncoming traffic, the LED's are way better than the HID's in stock headlight capsules, in my experience. The LED's are designed to fit the stock housings, so they scatter much less light into the eyes of oncoming traffic. I've never been flashed while driving my son's toyota, even on long straightaways when the oncoming driver had plenty of time to let me know the lights were bothering them. Some of the LED bulbs even advertise that they're DOT approved.
I don't know how else to solidify my statements besides pointing out the obvious logic that LEDs bulbs, just like HIDs, are way too bright for the halogen housing to properly focus the light output. This results in blinding oncoming traffic. This is also why no vehicle from a factory uses an LED bulb for their low beam without having a projector setup.
Here's a Jalopnik article on the issue as well.
https://jalopnik.com/should-you-swap...eds-1728026383
LEDs in halogen housings have been discussed all over the internet, feel free to look around other car enthusiasts' forums as well.
HIDs are also designed to fit stock housings as the fitment is standard industry-wide (H11, 9001, 9011...etc) so the LED bulb's ability fit in the stock housings does not validate their use in stock housing. Also, never "been flashed while driving my son's toyota , even on long straightaways" is not an accurate metric to determine whether or not your lights are too bright.
Any problems with the radio interferance I have read?
The one thing you have to watch out for is reliability. Quality is really variable between different brands - the first set of LED's I bought burned out in 3 months. The second set, which came with a 3 year warranty, has been working fine for over 2 years.
My advice would be to not buy the cheapest lights and instead opt for a set with a warranty. Don't buy the most expensive set, either - these things are like fishing lures. Some of them are designed more to catch the fisherman than the fish, if you know what I mean. Buy a set that has a decent warranty. I've been real happy with .
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Good info for those wanting to upgrade their lights (that's everyone who drives their C5 after dark) and don't want to pull the trigger on a good set of projector lights.
Especially good to note the DOT certification. Thanks, sstonebreaker!
However, I will say that even after using the MostPlus, I was still very impressed when I switched to the RadioFlyer set up.
They saved my car, these headlights. I was coming back to Fort Worth from Roswell NM one night and came around a curve and lit up a whole herd of feral pigs. I was able to stop in time to keep from hitting them. Had I still had the stock halogens, I believe my car would have been totaled.
