HUD Dimmer Knob Replacement
Old 09-23-2018, 09:57 AM
MacA1979
Always Shiftin'
Support Corvetteforum!
MacA1979's Avatar
C5 of Year Finalist (stock) 2019
Default HUD Dimmer **** Replacement
My "new-to-me" 2004 Z06 is missing the small HUD dimmer ****. I actually found a replacement online similar to pic below. The little "H" shaped clip in TINY! I can't find any instructions and was hoping someone else here has installed one of these to give me some pointers. I do not have the most steady hands and I am afraid I am going to lose the clip trying to figure out how to install it properly.
THANKS in advance!
Old 09-23-2018, 06:55 PM
MacA1979
Always Shiftin'
MacA1979's Avatar
Wow! I thought this was actually going to be an easy question. So nobody has had to replace this ****? I actually tried the clip in a couple of different configurations but couldn't get it to hold. I am sure I am just missing something.
Anybody??
Old 09-24-2018, 01:46 AM
laurent_zo6
laurent_zo6's Avatar
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Anybody??
PRODUCT DESCRIPTION
Snaps into place on HUD dimmer prongs.
Old 09-24-2018, 06:50 AM
MacA1979
Always Shiftin'
MacA1979's Avatar
Originally Posted by laurent_zo6
PRODUCT DESCRIPTION
At the risk of sounding like a smart-***, is this simply a cut and paste from a website where this **** is sold? Or do you have first-hand knowledge of this installation?
The separate small clip has to be positioned properly for the **** to actually "clip" onto the prong. The clip has a unique two-sided curved (concave/convex) design. I am simply asking if someone has done this installation SUCCESSFULLY before and knows how the clip is positioned.
Old 09-24-2018, 08:54 PM
laurent_zo6
It's a cut and paste from a vendor.
Old 09-24-2018, 09:09 PM
Ed Ramberger
Ed Ramberger's Avatar
I ordered one last year from Southern Car Parts because mine was missing. Insert the spring clip into the **** before pushing it on so it grips the switch when you push it on. Picture is identical to what you posted.
MacA1979 (09-25-2018)
Old 09-25-2018, 03:31 AM
zetec87
zetec87's Avatar
I had to slightly bend the clip a little more than it already is. Give it some more curve for a tighter fit. I also used a dab of glue for extra insurance.
Old 09-25-2018, 07:11 AM
MacA1979
Always Shiftin'
MacA1979's Avatar
Thanks for the reply, but I am still having a tough time visualizing this! And believe it or not, I do 90% of all my mechanical upgrades on my vehicles!!
So, the wide portion of the clip actually spreads the "jaws" of the switch prong as you push it on?
I did a REAL CRAPPY drawing, but is this the way the clip will be orientated on the switch prongs as the **** is pushed on?
Old 10-22-2021, 09:48 PM
kramers31
2nd Gear
kramers31's Avatar
I recently had to replace the HUD slider/dimmer **** on my 2003 C5 and had the same issue of finding some decent instructions. It wasn't clear at all how to position the Spring Clip.
Firstly, I ordered the part/s from Amazon from a Company called Keen "C5 Corvette Head Up Display **** with Clip" for $15 USD. It did not come with instructions.
Secondly, because of the size of the parts and my old eyes, I had to use tweezers and my LED headset magnifiers to do the job. And with much trial and error and dropping the parts several times, I finally figured out the proper fit of the sliding **** and Spring Clip to the Sliding Switch without using adhesive. Although you probably could use adhesive if you want.
Using the Spring Clip as-is was not adequate to hold the **** in place with a good amount of retention, so I modified the Spring Clip to have more "bow" in it using two needle nose pliers. Once I did this I placed the Spring Clip into the inside pocket of the **** with the convex side toward the inner rib of the ****, and pushed it onto the Sliding Switch, which now passes my subjective "tug test!" I took a closeup photo and hopefully it posts with this message; a picture is worth 1000 words...
Hope this helps!
laurent_zo6 (10-27-2021)
Old 02-28-2024, 03:40 PM
mikesurge
1st Gear
mikesurge's Avatar
Default HUD Slider Button
Hope this helps!
Thanks for posting your picture. I also ordered the HUD slider with the clip and was looking for the proper way to install. I superglued the convex side of the clip to the rib so it resembled your picture. The slider snapped on nicely and seems to be snug. I just wonder if the clip should have been flipped the other way to provide more contact with the slider arm.
Thanks again!
To HUD Dimmer Knob Replacement
Quick Reply: HUD Dimmer Knob Replacement
