Storing in non-heated garage for Winter....Tips?
Old 11-13-2018, 06:00 PM
FLEXjs
FLEXjs's Avatar
Default Storing in non-heated garage for Winter....Tips?
I didn't think finding storage for my Vette would be that difficult but it was a total pain in the ***. So many ******* advertising spaces and they don't reply to inquiries or calls. Made a deal with a dude to keep it in a condo building temp controlled secure garage on Sunday, then he ghosted me when I asked when we could meet to exchange cash and entry fob.
So anyway I got a 10 x 20 garage type drive-in storage unit today. Totally secure. But not temp controlled. It's around the corner from my office so I can go start the car regularly and I will keep full insurance on it so I can take it for short drives if the weather is not bad. It's going in on Saturday. Has a full tank of fuel and a fresh oil change.
Anything else I should consider? Maybe overfill the tires? If so, how much?
Old 11-13-2018, 06:09 PM
speedlink
speedlink's Avatar
I would not start it periodically, unless you drive it to get it up to normal operating temperatures. I would also add Stabil to the gas. There have been some who say only have about 1/4 tank of gas, so as to not foul the fuel pump. I have normally stored in the past with a full tank and Stabil.
The following 3 users liked this post by speedlink:
Hotstick11 (11-16-2018), owc6 (11-15-2018), Thunder22 (11-17-2018)
Old 11-13-2018, 06:10 PM
eseibel67
eseibel67's Avatar
Changed oil - good. Dont bother starting it until spring, engines wear most at cold start. And run the tank down well below 1/4 for storage to prevent sulfur buildup on sending unit. Overfilling tires a bit is ok to help prevent flatspotting, but I find that tires go back to round fairly quickly when driven again.
Old 11-13-2018, 06:13 PM
FLEXjs
FLEXjs's Avatar
What about the battery? Wouldn't it likely be dead in 5 months without starting it occasionally?
Old 11-13-2018, 06:16 PM
c54u
c54u's Avatar
Keep it plugged into a battery tender/maintainer.
owc6 (11-15-2018)
Old 11-13-2018, 06:21 PM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,724 Likes on 5,600 Posts
Really need a battery tender, if storage unit doesn't have power might want to look somewhere else. Other than that, you don't have to do much if only storing for 5 months.
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
Mice can do quite alot of damage over the course of a winter.
Old 11-13-2018, 07:54 PM
rmorin1249
rmorin1249's Avatar
Received 1,738 Likes on 1,174 Posts
St. Jude Donor '15-'16,'18
If no power in the storage unit and battery is good take it out and put it on a tender/maintainer.
Old 11-13-2018, 08:33 PM
fnbrowning
fnbrowning's Avatar
I've got to remind you guys that a number of Corvettes slumber outside on dealership lots over the winter, with nothing more than an occasional battery charge.
While I agree that we like to maintain our babies, realistically, other than looking after the battery occasionally, you don't have to worry this hibernation. Follow the advice against idling the engine. Don't start a cold engine without a plan to drive it somewhere.
The following 3 users liked this post by fnbrowning:
Inferno24 (11-14-2018), owc6 (11-15-2018), Steve_R (11-13-2018)
Old 11-13-2018, 10:04 PM
gmarcucio
gmarcucio's Avatar
I would give it a nice coat of wax and especially wax the wheels being they are sitting close to the ground with no detailing those months of not driving it. I always give my wheels a nice coat of wax all year round on all of my cars and it pays off people always ask me how I keep my wheels looking so nice!
Old 11-13-2018, 10:26 PM
JDSC8VETTE
JDSC8VETTE's Avatar
Received 2,899 Likes on 1,161 Posts
Battery tender, fuel stabilizer, car cover and if there is a possibility of mice getting into it I would get a carbag that zips around the car. These are all the things I have for my car and I'm storing it inside the garage attached to my house. I figure I have about 600 bucks US invested in all the stuff I mentioned but it's peanuts compared to what I'm protecting for almost 5 Months a year.
Old 11-13-2018, 10:57 PM
Matthewstorm
Matthewstorm's Avatar
What do you use for Stabil in methanol?
Old 11-13-2018, 11:31 PM
Zjoe6
Moderator
Support Corvetteforum!
Zjoe6's Avatar
Received 3,938 Likes on 2,425 Posts
Startron.
Matthewstorm (11-14-2018)
Old 11-14-2018, 12:08 AM
sandcracker21
sandcracker21's Avatar
Like others said, battery tender is important.
I use stabil in a 100% full tank and a battery tender. Other than that, I place 'stay-dry' in the interior (overkill)
Old 11-14-2018, 12:09 AM
X25
Sr.Random input generator
X25's Avatar
Received 1,466 Likes on 1,023 Posts
Agree with others on not starting the car during the period. Regarding how to keep engine lubricated when it's time to start months later: keep your foot on the gas (full throttle, 100%, or it won't work), and then push the start button. This will cause the engine to crank but not start, oiling it at very low RPMs. After that, just start it regularly.
Old 11-14-2018, 07:22 AM
JDSC8VETTE
JDSC8VETTE's Avatar
There are many products including Startron that work well with Ethanol. Some guys swear by seafoam and that's all they use.
Old 11-14-2018, 10:02 AM
fsvoboda
fsvoboda's Avatar
Stabil and battery tender, and it should be fine. That's what I do. No power to storage unit? Pulling the battery and putting it on a tender might be useful, but I regularly store my boat without a tender over winters and have no problem, just trickle charge up to full voltage in spring and am good to go. One battery replacement in over a decade.
C7s are no more fragile than any other car in long term storage so far as I can see.
To Storing in non-heated garage for Winter....Tips?
Old 11-14-2018, 10:31 AM
JDSC8VETTE
JDSC8VETTE's Avatar
Your boat doesn't have any electronic draw on your battery like the Corvette does. You will kill your battery unless you either battery tend it or remove it and battery tend it somewhere else.
Old 11-14-2018, 10:37 AM
Mayor111
Mayor111's Avatar
Received 1,956 Likes on 942 Posts
Winterizing Tips (some may be overkill but Im listing them anyway):
Wash, clay and wax the car
Fill tank to full or 1/4 tank (depending what you believe) and add Stabil
Put Battery on Tender
Inflate tires to 35 psi
Change oil and oil filter
Lubricate all weatherstripping (doors, targa, Vert top, rear cargo, hood (use Meguiars Ultimate Protectant or Mother's VLR)
Clean and condition leather areas of interior
Lower windows down about an inch
Place something (soft) under tires (old floor mats, rubber shop mats, etc to avoid moisture and flat spots (many will argue this and say its not needed but I do it)
Get a "good" indoor or outdoor cover (depending where your Vette is parked for the winter)
Kiss her good-night and go cry till April...
The following 3 users liked this post by Mayor111:
Formula52 (11-14-2018), kaufmansm (11-15-2018), ZERRY 316 (11-15-2018)
Old 11-14-2018, 10:42 AM
Inferno24
Inferno24's Avatar
I couldn't agree more! I think some over think the whole storage thing and that's fine it's your car. I bought my 2018 last October and only put around 500 miles on it before it got put away for the winter. I took it for it's 500 mile oil change, gave it a quick detail and backed it in the garage and put a light indoor cover on it and plugged in the battery tender. I didn't do anything to the tires and they were still pegged at 32 psi in the spring.
This year I just recently took it for it's second oil change at 4600 miles, detailed it the other day and backed it in the garage. I don't have the tender on it yet or the cover on as I am hoping to get out a few more times before winter really sets in.
Lee Hunt1919 (11-14-2018)
Quick Reply: Storing in non-heated garage for Winter....Tips?
