Fuel Tank Replacement Recommendations
I'm going to replace the fuel tank in 67 TPI coupe. I've narrowed my search down to Rock Valley or Rick's Tanks for stainless tanks. Does anyone have any other fabricators I need to consider? These seem to be the two most posted about on this forum. I have a leak around my sending unit, and I'm not going to fix it. Sender needs to be on the top of the tank
Thanks!
Thanks!
Its on the very, VERY pricey side, but I've entertained this for the future fuel injection conversion....factory tank with fuel safe bladder http://fuelsafe.com/sa107a-corvette-fuel-cell/ Like I said, super expensive, but takes the 25 mph rear end collision/ fuel bath out of the equation. Just depends of how frequently you drive your car I suppose.
That being said, you can't go wrong with Rock Valley or Rick's as far as a quality product.
RFJohnston (11-15-2018)
Thanks!
Thanks!
Received 5,554 Likes
St. Jude Donor '07
yes
I can't seem to post pictures, so check this thread
https://www.corvetteforum.com/forums/c1-and-c2-corvettes/3374659-in-tank-fuel-pump.html
Bill
Bill
Thanks!
Thanks!
I used the Tanks Inc. TM33A-T. It uses the sender and intank fuel pump from the top. Fit and finish were nice. If I recall, tank, pump and sender were less than $500 about a year ago.
Jon
Patrick03 posted his while I was typing! However, I could not run the lines as he shows, I had to go over the side as there was not enough clearance between the lip on the front of the tank and the body of my '63 convertible.
That’s cool, Patrick, do both manufacturers mount the fuel pump from the top? Also, I see you are using the late model Corvette filter/regulator. I used this when I put the LS in my 1988 Defender and it was flawless. (OP, sorry if this is a hijack, please post what you decide to do and why, thanks!)
Off to the garage to pump my FULL gas tank into other vehicles. Then pull the tank. My existing tank is fine, but I'm changing the tank out because I had a return line fabricated into the existing bottom mounted sender plate. I've had the senders base plate crack twice now (assuming from vibration - about 6 years apart) and fuel leaking out of the bottom of the tank. Top mounted sender and both fuel lines will solve that problem. No desire to burn my house down...
