One job ends, another begins
There aren't a lot of things that need to be done, but the somewhat loose steering had to be addressed before wife starts driving it. From the outside looking in, the rag joint didn't look bad but is one of those safety things you replace just 'cuz. Good thing I did...
So the other job that begins? Well, when pulling it in the garage the fuel pump started puking fuel, so the wife will have to wait a little longer. Any tricks to replacing the pump on a '73 L82 with air? Doesn't look like it's gonna be any more fun than replacing the rag joint.....
Art17 (11-18-2018)
Received 1,246 Likes
I do everything from underneath. You can also also remove the front passenger wheel/ tire. You then have a straight shot at the pump bolts with a long extension run between the top of the frame and inner fender.
Before you pull the pump you need to have two special curved hoses to replace the ones that are coming off.
Unless you know how long since last change, just change them.
Before that, besides having to work quickly you have to have a way to pinch off the feed line or you will spill a lot of gas.
Dementer sole survivor
Received 6,291 Likes
2016 C3 of Year Finalist
when you buy the pump make sure the fittings are pointing the same as your original. AND by the best pump you can, the one I bought came apart internally, the swagged metal that help the pivot shaft in place just failed, the only way I new was the fuel pressure dropped for no good reason.
I used an old hacksaw blade to hold the pump rod from the camshaft in place while bolting in the new pump. I tried heavy grease, but it would not hold the shaft up in the bore. When I changed the pump on a '73 L48 A/C that I used to have, I did everything from underneath instead of putzing with the A/C compressor. And yes - get those proper fuel lines - and if you don't have the original metal line up to the carb, replace that while you are at it.
Thanks for the tips. Ordered an ACDelco replacement pump with the S hose and vapor hose. As long as freight was cheap I also ordered new P/S hoses as well. Look original and as inexpensive as they are it doesn't make much sense to run the originals.
Hacksaw blade? I pull the dipstick and use that. Then I heard about the jam bolt for the pump drive rod.
Replaced the pump today and the process was a bit different than others. I looked at trying to pull it from the bottom, but there was just no way to get a hand up in there let alone unbolt the pump. Wound up pulling the A/C compressor (was discharged already), the air injection pipe and bending the lower hose out of the way. Everything but disconnecting the hoses was from above. Used heavy grease to hold the pump shaft in place as the bolt trick wouldn't work. New hoses and the job's done.
Tomorrow is new P/S hoses. Knocking down one issue at a time........
Its_hers (12-22-2018)
