PDR SD card
PDR SD card
I just bought a SD card for my PDR and it doesn't seem to work. Is there a specific type of card I need to buy. I simply picked up a 32 SD card from the local CVS.
Thanks for your help.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I'll send you a simple to use app that will format it correctly, at least on a PC. I don't know if it's compatible with Apples. Just download it & you can format your card in less than a minute & you'll be good to go. I'm running a 64GB card but there are others who run 128GB cards etc....
OP, if you're not computer literate, enough, but have other accessories (dash cam, action cam, cell phone...etc) you can use those to format the SD card. 90% of dash cams and action cams will format the card in FAT32.
Received 1,622 Likes
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
make sure the little switch on the side is not set to 'ready only' or the car will not see it at all.
little tiny slider on the side.
I just plugged it in and it worked.
I've used two cards; both worked right out of the package.
I have witnessed that the PDR likes to see (sense) the insertion of the card for the first time. Try starting the car, wait about 30 seconds, then insert the SD card. Wait another 30 seconds, then launch the PDR program.
Just wondering if the OP checked price/availability from Amazon.com for the PDR 32 card. Lots less $ IIRC.....
Formatting SD cards using the Windows format command can cause "issues" in certain applications...
There are a number of programs that are available for formatting SD cards.
Perpetuating the stereotype that this is an OLD man’s car...I can’t believe the level of, or the lack of computer technical know how of THIS group. It’s like my dad asking me to program the VCR all over again.
FAT32 refers to 32bit architecture of older windows operating systems, like Windows XP before NTFS is widely adapted inlater iterations of Windows. The 32bit architecture limits physical partition size to 2 TB (off the top of my head?), not 32 GB. There are other limitations such as file size limit, but you can format just about any SD card in FAT32.
In fact there are multiple 500GB hard drives on my desktop computer that’s formatted FAT32.
sd card
ok, so if everyone else can use a card right out of the box, what am I doing wrong? My PDR still cant read the card. I hate to take it back to the dealer but I see no choice.
Some cards don’t come formatted, or they’re formatted NTFS because FAT32 is an OLD standard. No Windows 10 machine can natively format FAT32, you need an app like Rufus if you have Windows 10, or throw it into another machine/camera/whatever that can format it, as most cameras format in FAT32.
