Tire temp always says warm now
I had my wheels swapped out and a week and a half later the car has not responded to the change in temps. It always says warm. It use to say cold when it was actually cold out and now it is stuck on warm. I am not familiar with the system, so I do not know where to begin on this one. The tire pressure is reading accurate on the DIC, but even when at 39° it still says warm, which should read cold. (I have put on over 100 miles since then btw)
Anyone want to chime in on this one? Any and all thoughts would be appreciated here.
Again, thanks in advance!
Received 3,439 Likes
It's not an uncommon issue. Here is a thread that may help. I used to live in Portland, Or, and now Lake Havasu, AZ. I have never seen anything but warm on mine. It is actually reading the temp of the computer chip as they say for whatever that is worth, but have a look. I actually don't consider it a problem. Ihttps://www.corvetteforum.com/forums...display-2.html
Yesterday I drove my 2018 Z06 on a trip of 150 miles. The temperature at the beginning of the trip was in the low 40's. My tire temperature indicated "cold" and stayed that way for about 100 miles. Eventually, it switched to "normal" when the outside temperature got into the mid 50's.
I read that thread and all it did was confirm that there is an issue and it is going to effect the cars nannies. I have nothing to unplug or mess with and the sole change to the car was a set of wheels. Anyone else have an idea?
Mine says warm in 32 degrees, at 80 degrees, and also doing 140mph down the back stretch at COTA on my 8th lap. Until reading this I assumed it was just a gimmick and always said warm.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Almost 5 years with my C7 and I've never looked at that. Still won't. Why worry about it?
Side GRRR: I am not looking forwards to having the tires replaced but I will be glad to get these MPSS off the car. They are just too slick, if you will, due to the manufacture date I assume. 8/32" tread, so basically new but the date code is 4 yrs old.
Thanks for the feedback so far everyone! I haven't found a local dealer that doesn't seem overly crooked, after talking with 3 service managers, so I am avoiding them like the crack head begging on the street corner down town. lol
(100th post! woohoo lol)
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Mine used to say cold when ambient temperature was 32 or below. Now it says WARM all the time. Crazy.
Sooooo, nobody else has this issue and found a solution aside from the guy in the other thread that needed to unplug his power converter thingy?
I have not had this issue. However, I drive my GS in most kinds of weather, and if my tire temperature was not properly registering, I would get it fixed. I have driven in temperatures as low as 21F and I want the information on my tire status to help me adjust my driving.
Yourconfused (12-16-2018)
Moderator
Is your car kept outside or garaged where it is much warmer? How cold has it actually gotten in Austin? Air temp alone is not a good measure. Your tires are sitting on the ground (cement/asphalt) and that still has a fair amount of retained heat that, in turn. is transferred to your tires and the TPMS (where the temp sensor is).
Here's the temps and resulting display:
I daily drive mine in the Dallas area and I have not seen Cold yet this season.
I've only ever seen "frozen" once in the 100,000 miles I've had my car.
I was in Augusta, GA, and was wanting to make it home between storms. The car was parked outside at a hotel, and it was 23 degrees (4 am) when I started out and it read frozen, It took 20 minutes to get to cold and then another 10 or 15 to get to warm. As I drove east, the temp dropped, but the tires were warmed, so they were just fine. Just as I reached the 95 corridor, the sun came up and the temp dropped even further to 9 deg. I stopped for gas, and took it easy getting back on the freeway, but it really wasn't a big issue.
I thought my tires would crack and fall off the car, but they didn't.
I also drove through some blowing snow in Virginia, but the car didn't blow off the road, or end up in a ditch.
I made it home after a 4000 + mile trip , and It turned out that the tires in cold weather weren't all that big a deal if one is careful.
Received 19,307 Likes
'20-'21-'22-'23-'24
Haven't really looked at that display yet. Now my curiosity is peaked.
