Clutch replacement
Clutch replacement
2003 Z06 with 75,000 Miles
This upcoming spring I have decided to address my sticking clutch. It appears that when the car is hot occasionaly the clutch pedal will stick to the floor or the clutch might slip when hitting the nitrous. I know its really hard to bleed the clutch. I have done the ranger method, but it still sticks occasionally. I'm going to address the issues while its apart. Clutch, torque tube bearings, couplers, and master/slave cylinders.
I'm looking at the LS7 clutch and re-surfaced flywheel. Should I go with OEM or aftermarket Master/Slave Cylinder? Is there anything else that should be done while its apart?
I just did the clutch et al on my ‘99 FRC 2 weeks ago in my garage. It had 80,000 miles on the stock unit.
I replaced the clutch with a monster level 2 and 18lb flywheel. The kit came with a pilot bearing, new bolts and a slave cylinder (measured and no shims were needed). Ordered from Tick.
I also installed a tick remote bleeder.
I had the transmission rebuilt by RKT Performance while it was out.
Rebuilt the torque tube with new bearings and couplers.
Replaced both axle seals and the driver’s side O-ring in the differential.
Was as a big job, but well worth the time and effort.
Please PM me with any questions. Feel free to PM your number and we can talk through any questions you might have including part numbers, tips, etc.
I was considering doing this job myself, but I just have some jackstands and I have a feeling that this job is just too big to do without a lift. I don't have any issues with my transmission today, although I would like to know if I should look at replacing linkage for my shifter or not. That was the only item that I had questions about. I have seen some other posts where someone replaced their linkage with a good aftermarket U Joint.
The job, while a big one, can be completed without a lift. I did it with heavy duty jack stands that I purchased on Amazon. I had the transmission rebuilt due to a leak between the trans and extension housing plus the higher mileage. I didn’t want to pull it out again. Once apart, it was in surprisingly good shape inside.
Now that I’ve had everything out once, I wouldn’t hesitate to do it again if I needed to.
Like you, I struggled with having a shop do it vs. doing it in my garage. A lift would have made it easier, but there’s nothing like the satisfaction of doing a major repair on your own.
I did not replace any component of the shift linkage.
Zen Vet Master Level VII
Well Effen done. That is a huge job and you did it with "limited" infrastructure. You put me to shame when I complain about smaller jobs. from now on I'll just shut up and fix it.
And watching Rick at RKT Performance tear apart my transmission in under 20 minutes was a real treat.
Not to mention the savings in labor cost. More money for more mods!
I had my drivetrain out 3 times in 2018 and all I used was jack stands. But I would recommend a different clutch. TheLS7 weighs a lot and for a little more money's you can get something better. I've had 2 corvettes, both with sinking pedals. Both times I replaced with monster clutches and never had the problem again. The last one I didn't already had an LS7 clutch in it.
I have heard a lot of good things about the LS7 clutch. I would maybe consider a lighter flywheel to offset the rotational mass.
Is there another clutch that handle 550 whp that isn't crazy expensive?
Received 19,305 Likes
'20-'21-'22-'23-'24
Moved to C5 Tech.
I have about 300 miles on the new clutch and flywheel and can report that the clutch pedal feels very close to stock. No issues to report at this time. I am satisfied with my decision. My car is putting down 380hp at the rear wheels.
There are several reputable aftermarket clutch manufacturers. If you do enough research you’ll find pros and cons for each and second guess yourself to the point of insanity.
I’ll also add this...
If you don’t have a press, lineup a machine shop ahead of time to press the bearings off and on your torque tube prop shaft.
Also, I got lucky and my torque tube was the older style with bolts holding it together rather than the enormous snap ring. If you have the snap ring, inquire at a local GM dealer on whether you can rent or borrow the giant snap ring pliers to remove the snap ring. GM designed this tool specifically for this task. Is it needed? No. Will it make the job quicker and safer? Yes.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yea,, Rick Kim of RKT Performance is AMAZING at anything to do with C5/C6 drive trains.
If you want better shifting, replace the lower shift box with a modified shift box that one of the forum members makes. It has bearings instead of bushings and is MUCH more accurate. Its an amazing up-grade.
If the universal joints on the shift linkage are worn and have excessive slop, you can replace them with a replacement universal joint.
I do ALL my drivetrain work on jack stands. Works fine if you don't have a LIFT!!
Bill
Bill
Bill
Bill
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! That's the one!
I already have a tModz box. I would like to get the u joints replaced on the shift linkage but I don't know how I could do that. I will be having a shop do this job
