C7 Forced Induction/Nitrous C7 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
F1x vs 2200x
Old 02-18-2019, 07:47 PM
acz06
acz06's Avatar
Default F1x vs 2200x
Thoughts on these blowers on a 416 stroker build??.. car currently has an f1a94.. car has a sleeved block.. and a killer rotating assembly.. winberg crank.. Dyer rods.. CP pistons.. probably moving to edelbrock heads.. looking to move to different intake manifold also.. has port injection.. rps triple and 15 inch conversion..
Thoughts on blowers?..my builder wont run much past 20 psi on 4 bolt heads also.. fyi
Old 02-18-2019, 08:23 PM
USMCMICHZ06
Cruising
USMCMICHZ06's Avatar
Why not go TT?
Old 02-18-2019, 08:24 PM
acz06
acz06's Avatar
It's more money or I would do a single pro mod 88 or 91
Old 02-19-2019, 03:26 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
What comp on the motor plus are you using bolts are ARP studs if you are not running 11:7:1 pistons and have the studs you can do a little more on the boost level & it will live with a good tuner.. That other bolt on the head is only tq down to 40lbs..
You may look at 1/2 stud in the heads also on it to help hold stuff down better... Robert
Old 02-19-2019, 09:27 PM
3honkz
3honkz's Avatar
2200x if planning on staying around 1100whp. Anything over I would just go with f1x
Old 02-19-2019, 11:51 PM
black_c7
black_c7's Avatar
2200x isn’t anything better than the regular 2200r, maybe just 20 30 whp more, if you looking to make 1100+ go for the x for sure or stick with your f1a94
Old 02-20-2019, 10:29 AM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Your F1A-94 hits much harder than the F1X. I would leave it. You can make 1100 with what you have.
Old 02-20-2019, 12:29 PM
C7&7
C7&7's Avatar
Wrong.... The 2200X has the billet guts and housing. It is only 50cfm short of a F1X. I run the 2200x and make around 1100 on full tilt without the intake on the blower (26psi).
The 2200X is a blower that brings in the power at a lower RPM than a F1X which was important for me. I wanted to enjoy the car on the street instead of just turning a big HP number. I also did not want the vertical inter-cooler setup the procharger kit has. I had the novi1500 before with the horizontal IC and just switched to the 2200X head unit. Everything else stayed the same. ECS is also A+ when it comes to customer service.
Old 02-20-2019, 12:31 PM
C7&7
C7&7's Avatar
I agree with this. The 94 is a bad dude. It's not worth the money to switch to f1x or the 2200x. I'd spend my money elsewhere. Like port injection or something where you can run full e85. (if the OP doesn't have port injection already)
Old 02-20-2019, 12:45 PM
black_c7
black_c7's Avatar
I know ita has the billet impeller but does that make it any better than the r! NO the both have the same power limit that why i said if he want 1100 to stay with the f1a94 since he already have it, anything more than that f1x is his only route other than turbo.
Old 02-20-2019, 01:06 PM
C7&7
C7&7's Avatar
Dude...you're wrong. the X is considerably more blower than the R. It's not all about HP number it's about how much air does it move. The F1A-94 is 1625 cfm so it's more in line with the 2200R and the F1X is 2000 cfm.
Have a look.
Old 02-20-2019, 01:10 PM
black_c7
black_c7's Avatar
Have a look.
i totally understand that, but there is no real life results that show the 300cfm increasment over the 2200r
Old 02-20-2019, 01:20 PM
C7&7
C7&7's Avatar
Ok.... lol.. I'm not going to argue with you. The point is they don't "have the same power limit". They are in fact blowers with considerably different potentials. CFM's don't lie.
However to your point the 300 or so CFM is splitting hairs in any blower setup. Hell the f1a94 to f1x is just 300 ish cfm different. It's not worth the money to change but the X will make more power and have more future potential just like the 2200x would over the R.
Old 02-20-2019, 02:07 PM
acz06
acz06's Avatar
My gut is telling me the 94 will be plenty.. made 900 at 17 pounds on full e85.. not sure what the 416 will make but we will c.. still waiting in the crank.. winberg is so backed up.. I won't get it till April..
Thx for the great responses..
Old 02-20-2019, 04:23 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Stick with current blower.
Old 02-20-2019, 09:47 PM
USMCMICHZ06
Cruising
For reference I'm making just shy of 1100 to the wheel on race gas with a -94. Going to port injection and likely E85 next season; I saw one car in that configuration make 1180... Car currently makes 21 PSI and I can pulley down.
Old 02-21-2019, 01:16 AM
3honkz
3honkz's Avatar
You are absolutely right about that
To F1x vs 2200x
Old 02-21-2019, 10:11 AM
algZO6
algZO6's Avatar
i have ran a ysi-b with the nano coating and a f1x on the exact same combo. the x picked up over 150 at the wheels over the ysi-b and lost nothing down low....not to mention the x was still pulling when i shut it down at 7200
black_c7 (02-21-2019)
Old 02-21-2019, 10:23 AM
Unreal
Unreal's Avatar
All of them are great blowers, but if the OP is just going for 1000-1150, and has a f1a-94, it will do that with ease. Why change or mess with anything?
Old 02-21-2019, 10:26 AM
C7&7
C7&7's Avatar
He shouldn't at all. The 94 has plenty of headroom to accomplish his goals.
Quick Reply: F1x vs 2200x
