2014 Stingray
Navigator
2014 Stingray
Exhaust system seems excessively loud - has 17,000 miles. Is this normal? Was told that changing from E to T etc would change the noise level. True?
Most around here complain the exhaust is too quiet. If you have the performance exhaust then switching between Eco and Touring mode will change the sound.
Is this something that suddenly happened? Like quiet one day then loud the next? If the exhaust valves failed (for any number of reasons) then I believe the default position is open which would be similar to putting it in Track mode. Are any fuses blown? This link has tons of info on the performance exhaust system and what the fuses do: https://www.corvetteforum.com/forums...ck-result.html
MJZickert (02-19-2019)
If you have the npp exhaust you have a setting you can bring up the sound level desired from staelth to track mode check the owners manual to see how to do it
You can also tweak the steering stiffness too if I don't have my cars confused. I'm old and have too many.
Check to make sure fuses are installed
The following 2 users liked this post by hemistar1:
MJZickert (03-24-2019),
Rebel Yell (02-20-2019)
Check this link to verify which exhaust you have.
https://www.corvetteforum.com/forums...post1593775890
The NPP can be adjusted for sound. Quiet/Loud
The Non NPP can not be adjusted for sound. Only Quiet
Maybe you have an aftermarket exhaust which is loud all the time.
Received 19,303 Likes
'20-'21-'22-'23-'24
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
I have a 2014 with NPP. There is no difference in the exhaust note when changing from E to T on my C7. However, there is a noticeable difference when changing from T (Tour) to S (Sport).
Here is a chart from the owners manual from my 2014 Stingray with NPP. Note that you can override these changes by choosing to keep the exhaust in a particular mode by going into the settings found on the infotainment screen. There are lots of choices in there. I found when I first got the car that the best way to go through them was sitting in the driveway with the engine running and fiddling with the selections.
Looking at that chart again I see that there is a difference from Eco to Tour, although in my car I do not notice it. The difference going from Tour to Sport or Track is dramatic, though.
Also, I forgot to mention it in the previous post - Congratulations!
Did you buy it from a Chevrolet dealer? If so, go back to them with the car to learn about what you have bought, and possibly coaching on the car's settings. . They can also run the car's onboard computer OBC, and GMVIS reports on the car's history for you. It (should) detect modifying the electronic system may have underwent - if any...
If you have NPP option, the quietest option is to slave (link) it to drive mode and drive in Tour.
The prior owner may have replaced the X pipe so it may be louder than stock.... The first thing I did was pull the fuse and replace the X pipe, makes it sound so nice
Another thought - perhaps OP has an aftermarket exhaust installed...?
NPP Issue
Great thread, lots of informed discussion. Am hoping one of you knowledgeable folks can shed some light for me.
Took me awhile to find the source of a rather concerning, loud metallic “clanging”, but I finally observed my NPP valves rhythmically slamming shut, opening, and slamming shut, more or less at 1 cps. Happens intermittently, first noticed at startup but has happened while driving (probably below 35mph only, but not 100% sure on that). Typically stops on its own accord after 10-15 cycles. Sometimes changing exhaust mode correlates to it stopping, but that doesn’t always stop it.
Car is 2016 Z51 with mag suspension, performance exhaust, and manual transmission.
Any thoughts on potential causes would be appreciated!
