Smoke from starter?
Smoke from starter?
On Saturday we took our '67 coupe (300hp/327) for a nice drive, stopping at a restaurant for dinner.
After dinner we got into the car and I turned the key to engage the starter. The starter turned over the engine normally at first, but then it seemed to sputter, followed by 'KLONK' type noise. I turned the key off immediately upon hearing the noise. Then I noticed a burning smell, followed by smoke coming from the vents at the back of the hood near the windshield. I grabbed my fire extinguisher, popped the hood, and jumped out of the car, expecting the worst - an engine fire. But I could see nothing aflame, just smoke. This cleared fairly quickly and I could see nothing from above to indicate the source. I knelt down to look underneath, but could see no apparent source of the combustion.
Once the smoke had cleared, I started the car, which sprung to life normally. Puzzled, I drove home, wondering what had caused the earlier klonking noise and subsequent smoke.
Yesterday, I drove the car again. It started normally, no strange noises, or smoke. I drove it to a couple of places, turned the engine off, and it restarted without issue. So, since the smoke event on Saturday, I've started the car at least five times without incident.
My current theory is that the smoke may have come from the starter. Is this a reasonable supposition? If not the starter, then what else could cause a klonking noise then smoke?
We're planniing to take this car on an 800 mile road trip in May. As the car is an automatic I'm thinking it might be worthwhile replacing the starter now, instead of it blowing up and stranding me far from home.
Your thoughts?
Your thoughts?
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
Actually....I'm Speechless!!! That is really unusual....I mean that I'm speechless! Might not be the starter at all. IMO, if that KLONK and smoke was from the starter I think it would have been "Cooked"......Any chance it was Carb "Backfire"?
Received 1,844 Likes
You likely have some melted insulation somewhere. Start looking.
Received 2,136 Likes
I would check all wiring, connections etc for anything not normal. Dennis
Received 1,760 Likes
2018 C1 of Year Finalist
[QUOTE=MikeM;1599107781]The vents at the back of the hood do not vent the engine compartment. If the smoke did come out of those vents, the smoke had to come out from under the dash.
You likely have some melted insulation somewhere. Start looking.[/QUOTE]
And don't drive it until you find the source.....
Received 5,612 Likes
It’s hard to put the smoke back in once it escapes!
You may be able to see the roasted wiring if it is under the dash. If you can get your head and body into position with a strong light, fried wiring is pretty easy to see. However, does everything else work normally? Is your clock still running, does the radio (if you have one) still work, and other changes that could be related to the up in smoke situation?
The smoke may have been coming from the rear edge of the hood and our guy only thought it was coming from the cowl vents....
First rule when this happens. Always, always disconnect the battery and remove the center ignition shielding and check the pink wires that pass under it to the ignition...
Look for cuts, pinches or melted insulation...
Second, check that there is no way the shield could contact ignition coil terminals...the coil should always be positioned as shown to preclude that happening (note the pink wires in the picture).
Received 2,148 Likes
2015 C2 of the Year Finalist
Dan
Gavin65 (03-26-2019)
Received 1,548 Likes
The clunk could easily be the bendix gear engaging the flywheel.
The OP states he has a 67 which is suppose to have fusible links - correct? I have witnessed fusible links smoldering and smoking even to the point of discoloring and deforming (melting) the jacket (covering) on the wire and still work.
I had a friend with a Chevelle that had a shorted connection on the solenoid. He fooled with it for 3 months and couldn't get the problem fixed. When he hooked up the battery, the fusible link would smoke. I found and fixed the short at the solenoid and the car has been running fine with the deformed, discolored fusible link.
The confusing part is the self healing short that created the hot wire and smoke. I would carefully inspect all of the wires passing near the exhaust manifold or header. If a wire came in contact and shorted and then during an attempting to find the problem, the wire was broken free, it would temporarily remove the short until the wire is once again moved against the manifold. Chevy originally had a harness (loom) on the wire bundle going to the starter, but that protection seems to have been a common delete when changing the starter.
Just a thought
Just a thought
Keep the smoke in the box I always say. Smoke in the box, good.... smoke out of the box, bad......
I don't understand from the post how much smoke was it? a cigarette level or a campfire? ie, one wire or a bunch of them?
Pull the starter, smell it and thoroughly inspect it. I had a starter go south on my 68 small block. The small ring holding the bendex gear in place failed which allowed the entire armature to slide forward and grounded the starter through the case. It cooked the battery cable and the starter. The fusible links were OK. I use an local old school shop to rebuild my starters and alternators. New bearing, brushes, and diodes are included. Jerry
Do not go on any extended trips as the starter runs on smoke. When it runs out, the car will not start.
Lucas Electric sells replacement smoke for all wiring problems. Make sure that you have a can ready in an emergency,
I think someone is “blowing smoke............”
GTOguy (03-26-2019)
Received 3,443 Likes
