Question For You Body Work Guys
I知 through fitting up and glueing on my new front and rear flared fenders.
I知 now to the stage where I need to blend it all together. My plan is to chamfer back the joints and then fill and level everything out. My question is what I should fill these joints with? My original thinking was to fill with a few layers of glass matt and resin and then top that with vette panel adhesive to surface. Now that everything is glued up though I think that might be overkill. I知 considering filling with only vette panel adhesive and calling it good.
I壇 appreciate any tips you all can share.
Tom
Tom
Tom
Tom
stripping my 75, the razor gouges the filler at the bonding strip seam. almost never cuts into the glass itself. i think chevy used essentially bondo. and it makes sense for the filler to be softer than the glass body. you lay up resin and mat on top of those flares and you are gonna have to be really careful getting it contoured.
grind back the white gelcoat and lay up fiberglass and resin. then finish with filler.
You want a really solid joint withh these aftermarket wide bodies.
if/when the custom suspension/wheel setup touches the fender; id rather fix a ripped up arch than risk a hairline crack across the entire qtr panel popping loose.
I only used VPA https://www.corvetteforum.com/forums...post1596423617, and NONN37 you're scaring me.
yeah okay. you know what that is really well done. ^^
I thought they were widebody flare kits that fit over the existing fenders. If they are glued in place like factory(with the originals removed) they are pretty solid.
id still go for mat on the seam though. since hes already at that stage it seems more solid since the vpa will be really thinned out by the time you shape and block it..
Never did the flares but lord knows I done the VPA. Have yet to see the VPA break down as long as the prep work is done. Personnly I would go right to the VPA and be done with it. Everyone has their preferences so you will have to be the best judge. I mean you could add a layer or 2 of mat and then go to the VPA. Don;t think that it would be overkill. Guess you'll have to pick one!
RVZIO
RVZIO
these are whole fenders that attach to the bonding strips. the top surface of the fenders and car body they attach to IS the top surface you are trying to blend to. if you lay up glass on top of that surface you are creating a high spot-stripe that you are not going to be able to blend in. you essentially have to sand it all back off. and it is as hard as the glass body. use mat and resin for structure. not filler.
